SOURCE: Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
SOURCE: it is leaking from what looks like under where the
** First, unplug the unit from the wall**
Remove the lower panel if you haven't already. Inspect the rubber seal/boot/bellows you spoke of. You'll likely find a tear in it somewhere, or a hole. Short of repairing it with a rubber tire/tube patch kit, it'll need to be replaced. I've seen many do-it-yourself-ers have success with the repair kits or some other epoxy/adhesive type fix.
(Be careful you don't want something that's going to come of during use and damage your clothing)
hope that helps, Good Luck
macmarkus :)
Testimonial: "thank you so much sure enough there was a hole"
SOURCE: GE model number WCVH6600HWW with a huge tear
I have the same problem and I'm thinking of trying to replace the boot myself. I found this at ehow.com. The instructions and pictures seeem pretty good.
http://www.ehow.com/how_5651102_replace-front-load-washing-machine.html
