Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Chrome flakes in steam unit of Saeco Digital Plus Espresso machin
When I use the stream wand, I notice small flecks on what appears to be chrome in the cup (when flushing out the wand after steaming the milk). I have recently descaled and rinsed the machine, but the flecks still are present. I don't see any flecks when I flush the unit after making espresso. I'm wondering if I need a new wand assembly or whether this is a boiler issue. Thanks.
    President:
  • 1,618 Answers
Flush the boiler a few more times with cold water atleast 2 more full water tanks.
Posted on Jun 30, 2009
Can I repair it myself?
Notice if you can hear the pump when you are opening for steam.If you dont hear it ther is a problem at the switch.If you hear it then the tube is just blocked with milk.
Apr 29, 2014 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
How do I ventilate my Saeco Magic Plus?
Open the steam/ hot water tap ie: run hot water through the steam wand.
Dec 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
I have a saeco Royal Professional and have noticed that although the steamer appears to have sufficient pressure it is taking longer to heat the milk via the wand and that it appears to be steaming up...
Very good description. The problem is very simple. Inside the machine behind the steam wand the secure nut on the pipe coming to the wand is loose and you can tight it back in place very easy. You will need to remove the top plastic cover to see where the steam is leaking.
There is a chance that the pipe or nut is proken but this is very rair.
Good Luck
Mar 27, 2010 | Saeco Royal Professional Espresso Machine
No steam or hot water
Check to make sure pressure is coming out of the wand, if not, there is definately dried up clog inside the tube somewhere or possibility that the hose is loose on motor.
Jun 18, 2009 | Saeco Incanto Classic Espresso Machine
I have my Incanto Deluxe for about 1 year. I have never had any problem making a good quality froth, but recently the frother is producing too much air and milk is becoming bubbly. I am religesly clean my...
I think you have a chrome steam wand end.
To froth properly, there is a very small hole on the side of the chrome steam wand that injects small bubbles into the milk, the hole is located aprox 1/4" down from top of the chrome wand, if this hole blocks up you can only heat the milk, not froth. I commonly use a stripped tin tie wire or a sewing needle to clear the hole . Clean the hole,do not enlargen the hole.
Mar 02, 2009 | Saeco INCANTO DELUXE Espresso Machine
The steam knob only turns 1/4 turn to left
Hi
!/4 turn is all the Magic and Royal machines will do. Don't try to turn it farther or you could break the steam valve.
Dec 26, 2008 | Saeco Royal Digital Plus Coffee...
Chrome on steam wand wearing off
consider this --it doesn't have to be chrome or brass or anything special
find an engineering shop that can manufacture one out of stainless steel
It meets hygiene standards , will not wear off with incorrect cleaners and always looks good
Mar 14, 2017 | Breville Die Cast 800ESXL Espresso Machine
Steam Wand broken
I think you have a tube in the machine from the rapid steam boiler that is blocked.
Best regards
/Mirran
Sep 25, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
105 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
