Question about Thomson Televison & Video
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully appreiatted
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Posted on Aug 16, 2011
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Hitachi C2143S TV
you have a very unhappy tv...sounds like you have a relay clicking, or worse, something about to fail. the led pulsing is a warning signal, and going pure red means that you have a major failure inside the box.
you doing the service yourself, or open to a service pro coming in for this?
Mar 07, 2008 | Televison & Video
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Technosonic LCD1908 stuck in standby. Does not appear to be flashing red LED as other posts mention. I have no remote. As soon as I switch on it just stays in standby with red LED.
There are several things that must happen before a DLP will turn on. The light bulb and color wheel must start first. Samsung had some color wheel issues. Check the bulb first. If it is good, most likely it is the color wheel.
Oct 14, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Red LED standby button is blinking red. Amplifier is switched on and after some 5 secs switches off on its own with red LED still blinking. If OFF on remote is pressed red LED stops blinking, however...
There is a problem win the power supply. I would look for swollen/leaking caps and also any cracked , broken devices in that general area and replace them
Sep 04, 2017 | Denon AVR-5800 Receiver
TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
May 12, 2008 | Televison & Video
Television reverting to standby
Hi Phil.
Try adjusting A1 on loptx it is very critical & can cause the symptoms you are describing.
You could be right in saying the crt, Philips tubes are notorius for failing.
Im hoping your a tv tech if you are not DO Not do what I have written below tapping neck to hard can cause seriouse injury to your self.
Run set & tap the glass neck of crt if pic flickers or you see red blue or green flashing while tapping tube neck it will be the tube.
Let me know results there are a few things that can be done.
Chris..
Dec 15, 2007 | Philips 32PW6006 32" TV
Televison & Video Logo
164 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
