Question about TruTech PVS31170S1W 17 in. LCD Television
While watching tv the picture blackens out and back in. What could the problem be?
  • 744 Answers
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner o), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact service tech and let them recommend an authorized service center in your area. Sorry, but this is a rather serious problem.
Posted on Jun 27, 2009
Screen is blackened on top of screen
assuming your TV is an LCD, there is an issue with the CCFL lighting tube/s and one or more needs replacing/repairing.
if your TV is LCDLED then there is an issue with your LED lightstrip - probably faulty circuitry and would need replacing.
unless you are confident with stripping your TV (which i doubt) then you will need to pay someone, and it will probably cost LESS to just buy a new TV -- they are getting very cheap.
Nov 21, 2013 | Samsung Televison & Video
Vizio VP50 10A picture has shifted to the right, how do I adjust back to full screen?
You have to get into its service mode option to make it right. For more details, visit the site 'Electro-help". You can search for it by typing this site name to your search engines' search box, and click search.
Jun 14, 2012 | Vizio VP50 10A 50 in. Plasma TV
Get sound and "invalid format" message displayed instead of picture
Could have still been hit by a surge. Take the back off of the TV and look at the main board were you connect your HDMI. See if it is scorched or components that blackened. Also check your DVD player on another set. Your DVD player could be the problem.
Apr 11, 2012 | LG Televison & Video
My tv turns on but screen is black!!!!!
inverter or bulb is blown
look very close to the tv and see if the picture is there but just blackened. if this is the case you need the unit serviced for a bad buld or inverter unit.
Jun 27, 2011 | Sharp Televison & Video
As I was watching tv, today, I heard a "pop" and the picture blackened on the tv. I have a mitsubisi 65 inch dlp. There is no picture, only sound.
There might be a shorted capacitor in the video amplifier section. You can locate it through the physical appearance of the capacitor it is blown up. Replace it with same value but you have to get first the voltage output across the capacitor it must be within the voltage capacity of the capacitor. If the voltage output is higher, there is problem with the voltage regulator in the power supply section.
Nov 17, 2010 | Televison & Video
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Philips TV Power problem
I can't be the fuse like you say it is not blackened or open. Set may have a loose solder joint in the power supply look around large IC's and resistors (anything that genrates heat) can cause this problem. A faulty high voltage trasformer can do this I will check and see if I have any info on this particular chassis.. Oh yeah the deguassing coill is not doing it.
Dec 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
TruTech PVS31170S1W 17 in. LCD Television Logo
108 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
