Question about LG DLE5932W Electric Dryer
Clean filter light flashing and making more noise than normal
I have no manual
There is an element where the lent screen is. It is the dry sensor. Check to see if it has lent on it.
Posted on Jul 01, 2009
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
When on d AC that clean filter option will gt on and it starts blinkng ...even after the AC ht on This clean filter light will be blinkning...how to off that or how to stop that blinking light?!
Make of t-stat? Normally you can hold down the "clean air filter" button or hold down 2 buttons for 3 seconds to reset the air filter reminder. There should also be a setting in the configuration mode to remove filter reminder. But you would need the installation manual.
May 24, 2015 | Filter Heating & Cooling
It making a noise and the ice maker stop working
Thank you for your inquiry, Joann siefert!
I see that your Frigidaire refrigerator is making noises and no longer producing ice. Have you attempted to replace your water filter? If your filter is bad that could cause ice to stop producing. I would recommend changing your water filter to see if that would help correct your issue. The noise could be a normal operating noise. If you have your manual you can look inside for normal operating noises. If you need your manual could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Jan 23, 2015 | Frigidaire Refrigerators
My culligan reverse osmosis system is making a "honking" type noise. I can feel the blue lines pulse each time it honks, every 10 seconds. What can I do to stop the noise?
There is a problem with the automatic shutoff. There may be carbon fines or debris in it. When the shutoff is trying to close it will have a chirping or light honking noise. Try running all the water out of the tank Make sure you clean and sanitize the filter housings when changing filters.
Here is a link for Culligan RO manuals.
http://www.freshwatersystems.com/t-manuals.aspx
RJ
Jun 11, 2011 | Culligan Sediment Water Filter
My vaccuum seems to clean, but makes a louder noise than normal
I would check and clean any of the filters also check the pipes for any blockages etc.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Dyson Vacuums
Oe flashing does not spin
It's the pump motor - I pluged it into the machine and ran a test cycle (service manual link below) and there was the grinding noise. NOTE - I also tested the spin through the QC test mode (see pg 15 of manual) and that worked fine. BTW I pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf
Jan 14, 2009 | Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
LG DLE5932W Electric Dryer Logo
259 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
