Question about Tomtom One XL GPS Receiver
My tom tom does not pick up a satellite signal
4 Suggested Answers
SOURCE: my tom tom is not picking up gps signal
I just connected to my computer and ran updates that I got from tomtom.com... It works fine now. Try it with the new software.
Posted on Nov 25, 2007
  • 313 Answers
SOURCE: can't pick up a signal
HAVE YOU TRIED AN EXTERNAL ANTENNA PLUGED INTO THE BACK OF THE UNIT.
Posted on May 29, 2009
  • 4090 Answers
SOURCE: I have a Tom Tom GPS and all of a sudden it says
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal…
  • The GPS signal was lost … sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Make sure battery is fully charged before use
Reset your device
Posted on Jul 26, 2009
My tom tomtom wont pick up a valid GPS signal
Firstly, are you indoors or in a garage? TomTom needs a good uninterrupted signal to get a clean GPS pickup.
Have you done any updates lately as they have a 'GPS Fix' each time which updates satellites and their possible positions?
Sep 23, 2017 | Tomtom GPS
Tom Tom 540 can't find satellite signal for past hour
The problem can be fixed by resetting the tomtom one xl gps receiver. Tomtom one xl gps receiver is common with this problem, after resetting it, it is most likely it will happen again. So be ready to keep resetting over time.
It most like is as a result of bad strength to search and detect the satellite. So you have to adjust the antenna also to a area where it can pick signals easily. This is quite uneasy because the areas to locate the satellite varies in terms of the location you are.
Software update will not fix this problem as well as the quickgpsfix, so the bes solution is for you to keep resetting it. Hope this helped. Thank you for using fixya.
Jan 20, 2011 | Tomtom GPS
Gps is not picking up satellite signal
tom tom has a new update to help fix it you need to go to tomtom home and connect it it to the computer and it a free download,mine did the same thing and the update fixed it.hope this helps.
Sep 15, 2009 | Tomtom ONE 3rd Edition GPS
Tom Tom loses GPS reception as I am driving around
Have you hooked your GPS to an internet connected computer lately?
The TomTom home software that comes with the GPS will update so that it knows were the satalites are for the next week. It will also update the software to the latest verson.
You could also try inserting the end of a paperclip in the reset hole on the bottom of the GPS unit.
If all this fails contact TomTom. I have found them very helpfull.
Jul 12, 2009 | Tomtom ONE GPS Receiver
My tom tom has totally lost signal ive had it five months can anyone help? thanks
plug in the usb to pc (computer)
download tom-tom home 2.6
create an account click update my device/one/go
cllick install gps quick fix
May 03, 2009 | Tomtom One V2 Car GPS Receiver
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
HTH
Peter
Mar 07, 2009 | Tomtom ONE GPS Receiver
No signal
I have a Tom Tom One and sometimes it behaves as if there are no satellites no matter how long it is switched on for but I now just drive off and within a few seconds (30 seconds at most) is it suddenly acquires the satellites and it's OK. It just seems to be a quirk of the device and it doesn't do it all the time.
If it still does not acquire satellites on the move then it is probably faulty and needs to be repaired.
HTH
Peter
Feb 06, 2009 | Tomtom One Europe v2 GPS Receiver
No GPS Signal in TomTom One XL all of a sudden
I suddenly lost the GPS signal today and could not get it back. All I got was the "No valid GPS signal". My solution was to tap on the GPS satellite bars when in the route map. this brought up the "Status summary page of the TOMTOM.
I then again tapped the satellite bar which brought up the "GPS Status" page. I then tapped the bar labeled "configure".
The radio button next to the option titled "Minutes (dm.m') was selected. I then moved the selection to "Degrees (d.d) and it started working.
I had just downloaded the GPS fix 5 days ago so it is not like this suddenly caused it to stop working.
This may not work for everyone but this is what it took to get mine working.
Cheers
Jul 09, 2008 | Tomtom One XL GPS Receiver
My tom tom is not picking up gps signal
Oct 16, 2007 | Tomtom ONE GPS Receiver
Tomtom One XL GPS Receiver Logo
1,168 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
