Question about Canon MultiPASS C3000 All-In-One InkJet Printer
Canon imagerunner 3025
How do i print configuration page so that i can see what ip address is to set up on network
  • 1362 Answers
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try doing a cold reset first, then check that DHCP is manual not Auto. then try to input IP address again. If the Network card is seperate then you may only have to replace the Nic
Posted on Jul 16, 2008
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
  • 521 Answers
SOURCE: Canon imageRUNNER C3200 Copier network setup parameter needed
through the keyboard in printer features,after entering ip address you must go to maintenance?restart printer?? give copier up to 5 mins to spit out config page..job done?
or or
If I understand your question properly I can help you. Press the "additional functions" button which is located to the right of the display about halfway down the the keypad. It has an asterisk look to it and what I believe is supposed to be a "look" of a human head. LOL. Press it and you will see a menu. Two columns appear. The last item of the left column should say system settings. Press it. I am doing this from memory so you may have improvise as my memory sucks. Once you press system settings you should see a new menu, unless you IT guy has blocked access to these features as many do. In which case I cannot help. In the event you indeed do have access you should see a new menu. Since I do not have a machine in front of me we can struggle together. Once you have selected system settings you will see a new menu that the second column in the right should say "network settings".Press it. Then you will see on the second tab tcp /ip settings. Press it. At this point you can change the IP address settings. The area where you are now will also allow you to change the DNS server settings and just about everything you might want. Once you have made the changes you wish to make......back out by pressing reset till you get back to the main copy screen. Now in order for the changes you have made to take effect you must turn the machine off and back on using the power switch located at the right side of the copier, at the rear of the right side, about halfway down the machine.Turn the power off, wait a few seconds , then back on. Within 60 seconds the copier will accept the the new network changes . i hope this helps you and take care
Posted on Aug 12, 2008
  • 2692 Answers
SOURCE: canon imagerunner Ir c3200 total reset
Here is the Canon support website. If you can find you model , you can download a manual which contain all the information that you need.I coundn't find it because I dont know enough about you printer. Ink? etc.
Posted on Jan 20, 2009
SOURCE: Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Posted on Jan 24, 2009
How to configure the printer on network printing
Print a configuration page. Look for the IP address under Network. Type that IP address in your web browser address and press enter. That should bring you to the printers internal web server settings.
Jan 22, 2014 | Canon iR 2022 Printer
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
Canon IR 1023if; trying to network with buffalo router and two laptops and a wireless desktop. subnet mask default gateway is laptopA laptopB desktop ...
Did you change the coper to static IP? If not then the copier is most likely still set for a dynamic IP. A dynamic IP means the number will change from time to time when the IP lease from the router runs out. Your computers are most likely set for dynamic also. This is not a problem and the use of dynamic IP's is very common.
If you print out a status page (also know as a configuration page) from copier/printer there should be a Host name listed along with the IP address. The host name is a name that always stays assigned to the network card (providing you don't manual change it). If you substitute the host name for the IP address when you are setting up the printer port the computer will always look for that name on the network when you send a print job.
The IP address and host name are both ways to find the proper device you are looking for on a network. Think of them the same way as a phone number. You dial your friends cell phone and it goes out over the cellular network looking for your friends cell phone once it finds your friends cell phone his phone rings. IP's and Host names work the same way.
Let me know if you need anymore assistance. If needed I can log in remotely and give you a hand.
Jan 28, 2011 | Canon imageRUNNER 1023iF Black and White...
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Go to
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
Pspcl drivers for ir400 machine
press the option switch
in screen press function
press print pages
see the ip address & install the printer on this ip
in your computer networks use tcp\ip is smaller than machine ip if machines ip is
computers ip is
Aug 15, 2009 | Canon imageRUNNER 400S Copier
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon MultiPASS C3000 All-In-One InkJet Printer Logo
87 people viewed this question
old marine
old marine
