Question about General Electric Microwave Oven
I have GE JES735-BJ02 that heats but makes weird sounds like a rumbling sound.
  • GE Master
  • 9,098 Answers
It could be a failing fan motor or magnetron.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
And, as with anything that is not working right, it should be fixed as soon as possible or it can get worse.
If it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Let us know if we can help further.
Posted on Jun 28, 2009
  • 396 Answers
It could just be the turntable which helps cook the food evenly. Remove the glass plate (turntable) and see if the ring with wheels on it is under the glass turntable. If it is put a coffee cup of water in run the unit on high for 30 seconds. Did it still make the noise? If no remove the water and put the ring with wheels on it in the center of the microwave. Place the glass turntable on top of the ring rotating it until it locks in place and will not turn easily. Try the water again on top of the glass turn table to see if the noise returns.
Posted on Jul 15, 2009
I have a kitchen aid khms 1850 microwave. When setting idle it continues to make a small rumbling sound and after 30 minutes it smells like something is overheated. I'll unplug it after a day and will...
That is the sound of the magnetron failing. The large capacitor inside may also be drying up and causing the sound. When the capacitor dries up further it will start blowing fuses.
Nov 24, 2013 | Microwave Ovens
Microwave making noise and no heat.
Sounds like the magnetron tube went out. Not cost effective to repair unless under warranty.
Feb 04, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave jvm2070bh02 that is not heating and the motor/blower sounds really loud
It's had it's day and is worn out best get down to Walmart and git yerself a new one for around $100.
Feb 04, 2018 | Microwave Ovens
I bought a ge microwave model jes735 in june from sams club. the middle of august it quit heating and i would like to know where to get it fixed. i can't find the receipt but i sent all of the...
You can contact GE Customer Service here.
If you registered your warranty, that makes things smoother.
If not, no problem, they'll go by the model, serial and date code and refer you to the nearest local servicer.
Aug 24, 2008 | GE Microwave Ovens
Sparking ? Power Surge ?
I had the same problem. I replaced the wave guide/cover and everything was fine. It is a piece of cardboard inside the microwave that covers the magnetron. Mine was saturated with grease, and was damaged by the fire. If yours is still intact and not that greasy, You can carefully remove it. Clean both it and the area inside the cavity with an alcohol based cleaner. If there is so much as a pin hole in the cover it will need to be replaced. When grease somehow gets behind the cover an arc is formed which causes the problem.
Dec 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Model JES735
Yes, the fan blade is hitting something inside.Usually by opening the microwave, you can slide or reposition the plastic fan blade on the shaft.Probably this happened in shipping to the store where you bought it.CAUTON:make sure the unit is unplugged before you attempt this.Other option is return for replacement.
Nov 06, 2007 | GE JVM1630 Microwave Oven
General Electric Microwave Oven Logo
240 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
