Question about Konica Minolta bizhub 250 All-In-One Laser Printer
To Blade Flip: RE: F-28-3 Error on a Konica 7020
Please tell me what is a hv error? What is a transfer/seperation unit? What is hv casings/sleeves? Sounds like a costly repair for a 10 year old copier. The thing is, it was a great copier until I got this error. Thanks for your help.
Jen
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    You need to call a qualied technician.
  • 32 Answers
When you open number 6 there is a corona unit in there(t/s unit) and on the adu outer door there is the casing unit, has 2 springs in it, wheh you take this off and split it the sleeves inside will be powdery.
very simple to fit these items, not that costly either. It would be cost effective to buy the whole of number6 with the t/s unit in it.
si
Posted on Jun 28, 2009
Sc 28-03
Replace the Transfer and Seperation housing which is located below the drum which has several very fine wires that carry HV during the copy process as the paper goes above them and below the drum placing the image on the paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 23, 2014 | Konica Minolta Office Equipment & Supplies
F-28-3 knoica error
F 28-03 The toner separation ON/OFF operation has been performed 5 consecutive times since the separation trouble detection signal was detected at start of toner separation.Please check the HV2 unit,the transfer/separation corona unit.If there is a paper in copiymg proces when this jam occurs the machine stops after completion of copied paper ejectiom.
Oct 01, 2009 | Konica Minolta DiALTA Di200 Copier
F-28-3 Error Sounds Like Gears Binding
this code means the transfer corona is shorting out most common cause is the ts corona terminal on the door needs to be replaced
Sep 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I have a Konica 4145 copy machine with error code 60
There is arcing from the transfer corona, HV wires underneath the drum these thin wires provide a HV allowing transfer of the image from the drum to the paper, and allow seperation of the paper from the drum. (p/n 5400-2605)
Aug 19, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7130 error
HIGH VOLTGE ERROR. try resetting by powering off and unpluging machine from wall outlett . Also try 47 mode output check HV units
Jul 05, 2009 | Office Equipment & Supplies
Need Service message for Konica 7020
High voltage circuit board is bad. Have you turn the macine off then back on (wait at least 10 second in between). to reset the machine and clear the code. if that code comes back after turning on and off. then a new circuit board is need. or have a service technician come out and look at the machine
Jun 18, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 7022 f28-1 error
check for arcing or poor connection. Check HV1 (p/n 26NA84011) connections and ground of HV, developing unit and the right side door HV casing for any arcing. Check PRDB (p/n 26TA-9021), CN27-4 for 24V DC while in idle or in the 47 mode w/o input.
....you may need a tech to clean all of the above first.
you need to clean and reseat the charge unit in the drum section.and transfer unit on the right side door
hope that help
let me know how you make out
Oct 24, 2008 | Office Equipment & Supplies
Konica 7020 fault F28
f-28 codes deal with a corona unit arching.
if its a f-28-1 its the charge corona on the drum unit. more than likely its a f-28-3 though which is a seperation corona arch. these models were notorious for the insulating material that transfers voltage from the machine, to the door then back to the corona would eventually break down and start casuing arching.
what to look for, open the right side door and halfway down you will see a black peice of plastic sticking out that is attached by to screws. this needs to come off, but to get this off you will also need to remove the door opening bar. a total of 4 screws and you can have the black plastic peice in your hand. once off flip it over and open the back cover up. you will see 2 grey peicesof insulating material, one will be burnt the other will be fine. from here on it is up to you as to how you fix it. using an insulating tape that is cut to the opeing is an appropiate fix but it must be able to withstand high voltages. put it all back together and it should work.
Nov 26, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
545 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
