Question about Maytag Dual Cool 29 cu. ft. Side-by-Side Refrigerator MSD2957
Refrigerator isn't cooling below 58 degrees and freezer isn't cooling below 18 degrees. What is the problem? IS IT WORTH TRYING TO FIX IT?
  • pgalliers Jun 27, 2009
    Thanks -- it's 10 years old -- would you say it's worth fixing or is this just the beginning of more problems?
  • pgalliers Jul 14, 2009
    Thanks for all your insight. I discovered the main temp control had been turned down (duh!) and when it was reset all functioned as it should. I thank you again for your time and expertise!
  • 614 Answers
Depending on age of unit. Sounds like a fan motor or defrost heaters witch can cost up to 300 to 400 to fix depending on the heaters or motor. Ask for free estimate before you commit to fix. Rus
Posted on Jun 27, 2009
  • James Stopp
    James Stopp Jun 27, 2009
    Most of the time when fix a defrost problem it stays fixed. Refrigerant system problems or compressor. Do not work out well. 10 years old is not old for refrigerator. But if you have it repaired for 3 to 4 hundred. I would buy the new one. My friend has a Hotpoint and he had the defrost heaters replaced. The part alone was 290.00 plus service. The next year the compressor went out and he had to buy a new fridge. Rus
  • James Stopp
    James Stopp Jun 28, 2009
    Well what did you decide to do. I always like to know for my peace of mind THANKS Rusty
Maytag Refirgerator Model MTB2156FE freezer not cooling below 32 degrees
HI PAUL.FREEZER NOT COOLING could be for many reasons.go through the basics first .1-check if your freezer is iced up 2 if yes defrost it all completely first .then turn on 3-if ok then your problem could be 4-defrost timer 5-defrost heater 6-t/stat.if not iced up then check /clean thoroughly the condenser unit 7-check con/fan 8-check condenser should be warm/hot.if cold and motor hot then it could be lack of refrigerant (internal leak?) hope this helps.ALI
Jun 30, 2012 | Refrigerators
Just today the refrigerator part of our refrigerator has lost its ability to stay cold. The temp inside is 58 degrees. The freezer part seems find. any recommendations.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 03, 2011 | Refrigerators
Refrigerator will only get 58 degrees no colder, freezer is working fine, dial on fridge is on coldest setting...help
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Its not getting cold and staying on 58 degrees
heatman101
Oct 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
The top freezer is working, but the bottom refrigerator is warm, around 58 degrees?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer side will not cool below 18 degrees. The fridge side is cooling at the set 37 degrees. What could be the problem as to the freezer not cooling to 0 degrees?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 23, 2010 | GE PSI23SGM Side by Side Refrigerator
LG refrigerator model #RB2055SL FREEZER COOL FINE BUT REFRIGERATOR HAS DECRESED COOL TO THE COOLEST TEMPERTURE 58-61 DEGREES. WHAT IS THE PROBLEM?
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | LG Refrigerators
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Refrigerators Logo
219 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
