Question about Dryers
Empty water light stays on and doesnt get hot
Only had for 2 weeks and was working ok til i emptied the water container and now the light stays on and its not getting hot, the machine is a hotpoint ctd00 reverse action dryer
    Problem Solver:
  • 17 Answers
Allways with this type of unit it is best to always empty the container after every dry,this is because when the water rises in the pump chamber it operates a switch which shuts of the heater and puts on the light. and they stick quite a lot,disconnect from power and rock the appliance from front to back quite hard and this should rectify the problem
Posted on Jun 27, 2009
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
My maker keeps on saying descale. but how do i do it.
17.3 Descale
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the message:
DESCALE
flashes on the display, you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the P button (the light over the button comes on) then press the button repeatedly until the
appliance displays:
DESCALE No
• Press the button (corresponding to the SET symbol flashing on the display) and the appliance will
display:
DESCALE YES
• Press the OK button to start the descale programme.
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one litre of
water.
For subsequent descaling, use descaler of the same type and brand as supplied (available from technical
service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
34 C o l l e c t i o n
• press the OK button.Descaler runs off from the hot water spout into the container below.
The appliance displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
Oct 22, 2013 | DeLonghi Prima Donna Avante ESAM6700...
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
When the appliance displays the message:
DESCALE
Proceed as follows:
• press the button (the light over the button comes on) then press the button repeatedly until
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
RISRINSING COMPLETE PRESS OK
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
My indesit is70c tumble dryer isnt working correctly. The light which tells you to empty the water is staying on the water draw isn't filling up with water and it does not get any heat. ( I Know I Am Blond...
problem is probably the pump that sends water up to the container. take small panel off back and pump and water container is exposed. power the pump independently and see if it works
Aug 05, 2008 | Dryers
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Dryers Logo
338 people viewed this question
Top Dryers Experts
Marvin
Marvin
