Question about Mackie SRM-450 System
There is crackling coming from the horn as soon as the power is turned on, the level of the crackle does not alter with the volume control, the cabinet performs fine otherwise ?????
  • Derek Williamson Jun 27, 2009
    The horn itself is fine, I tried a new horn and the problem is still there,
    its being generated from somewhere on the circuit board ??
  • 11,896 Answers
The horn speaker is wearing out. Inside speakers, there is a magnet, the speaker part is attached to a cone that slides over the magnet, They tend to make crackling noises. Try very gently to apply pressure to the horn and then release. If you hear a scratching sound, the horn will need to be replaced
Posted on Jun 27, 2009
  • Nate Stansfield
    Nate Stansfield Jun 27, 2009
    Oh I see what you mean. You will need to replace the resistor.
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
Crackling noise with my volume knob when i turn the volume
It's probably dust in the volume control. It gets in between the carbon track and the wiper that rotates on the track, or the resistive / carbon track inside the control is wearing out. As yours is stereo there will be 2 tracks and 2 wipers, one could be worn more than the other.
This should give you an idea. Inside Pot
May 05, 2012 | Audio Players & Recorders
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
Technics su-v560 stereo amp crackling
That is a common symptom of not properly grounding of negative side of the output of power amplifier section.Just resolder all component parts joint in power amp.sectiton and double the solder all negative ground.Also clean the pots of all volume controls and selector with a lighter fluid or desame that fluid so whatever sound or crackling noise eliminated and works normal again.. Hope it may help you;;
Jun 08, 2009 | Technics Audio Players & Recorders
Loud crackling / popping
Well gd stuart i think you need some new speakers
Jan 27, 2008 | Logitech Z-2200 Computer Speakers
Stereo receiver crackling noise
open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Aug 13, 2017 | Audio Players & Recorders
Mackie SRM-450 System Logo
1,156 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
