Question about Sony Ericsson Cyber-shot C905 Cell Phone
Cracked screen .. but not lcd... just plastic face... any ideas where or what i can do or how to take it apart..?
  • 315 Answers
OR
Have a look on ebay, type in your phone model and search for a new shell.
Posted on Jul 23, 2009
Go to your phone supplier branch and ask them and they will refer you to a another phone dealer and give you an ew screen.
Posted on Jul 08, 2009
How to check lcd flex video cable
Take the LCD Screen apart. The cable is on the back of the LCD and attaches at the top. To take the lcd screen apart remove the plastic strip that is around the lcd screen. There are screws under the rubber bumpers on the plastic strip. Once you remove the screws under the rubber bumpers, then the plastic strip can be removed. Then you'll be able to get to the screws on the side of the brackets holding the lcd screen.
Apr 03, 2012 | Computers & Internet
Logitech harmony one
  • Dear Sir:
    Turn off the power to your computer and unplug all cables connected to it. Remove the battery, if one is installed.
  • 2
    Locate the covered screws around the cracked screen. Remove the rubber or plastic covers, then unscrew the screws.
  • 3
    Gently remove the plastic frame around the cracked screen and set it aside. Disconnect any power cords or cables going into the LCD screen.
  • 4
    Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
  • 5
    Reconnect all internal cords to the screen. Screw in the frame and replace all the screw covers.
  • 6
    Reconnect the power supply and all external cables to the LCD screen and switch it on.
    sincerely. God bless you
    ernesto cuadra
    managua, nicaragua. c.a.
  • Feb 15, 2012 | Logitech Harmony One LCD Touchscreen...
    How do I replace the bezel and LCD back cover on my DEL laptop?I can't get the LCD screen or the "hinge" to come apart so I can replace the bezel around the screen as well as the back cover that has the...
    aound the screen in the plastic area there should be four plastic stops, very tiny, in each corner, there's screws under those rubber stops. use a tiny screw driver to pop them out, don't loose 'em now. after you remove the tiny screws, just pop the front face plate out with a small flathead screwdriver.
    Sep 15, 2009 | Dell Latitude D610 Notebook PC
    Lcd screen cracked
    You can get a new screen from www.lcdpart.com
    You can get dismantling info from them.
    Basically you need to remove screws from the lid and bezel to reveal the LCD screen mounting screws. You also need to remove part of the plastic case next to the bottom of the screen, this will reveal the video cable conector etc.
    If the top plastic case is in one piece, you need to remove this and possibly the keyboard to reveal the video cable connector.
    May 12, 2009 | Acer Aspire 5520-5908 Notebook
    Cracked case
    Hi there.
    You can order spare parts from Acer themselves or alternatively look on Ebay for spare plastics.
    It sounds like you need the lid face and bezel (plastic that surrounds the screen), as for disassembley i'm afraid its trial and error as you may have to take the laptop apart to replace the plastics.
    Good luck and thanks for using FixYa!!
    Mar 04, 2009 | Acer Aspire 3680 Notebook
    LCD Screen Replacement
    Here are some instructions.. The illustrated repair is not for sanyo.. But I'm positive that it will give you some idea as to how to begin..
    http://www.tebyte.com/2008/03/how-to-replace-nokia-6126-lcd.html
    Oct 03, 2008 | Sanyo Katana SCP-6600 Cellular Phone
    Taking the 1907fpt apart
    OK, thanks to hihai in another posting, I was able (finally) to get into my monitor. Use a wide, thin knife and insert it between the grey plastic and the black plastic at the top or bottom of the monitor. (its easier at the top or bottom as you can distinctly see the deliniation between the grey and black - on the sides it's all black and the fit of this bezel around the monitor is so tight it's really hard to get in to the crack to pry the thing off). At any rate, once you get your thin knife (I too used a butter knife) into that crack, gently slide it to one end or the other. There are tabs near each end and a couple in the middle - you'll feel a bit of resistance near each tab as you slide the knife. Position the knife close to one of the end tabs. Rotate the knife handle outwards away from the monitor effectively prying the bezel upwards away from the face of the monitor. As you pop each tab, work towards the opposite end of the same side of the monitor. Once you have both ends dislodged, inserting the knife to pry up the all black sides will be easier. Unfortunately once you have the top (or bottom) and both sides loose the remaining top (or bottom depending on which one you started with) becomes a bit tighter to get the knife into.
    Here's my word of caution. Be very gentle. While I was trying to find the way to get the bezel to come off I attempted to slide it in between the monitor face and the bezel itself and unfortunately cracked the glass face inside the monitor rendering it useless.
    As for the power button, the button had worn down so much from use there simply was no travel left to push the contact on the switch board in the bezel. I tried a dab of hot glue on the inside of the power button to give it some more contact to the switch on the circuit board but didn't have enough. I was able to push the switch on the board with the circuit board removed from the bezel (with a tiny screwdriver not my fingers) and the monitor powered up fine. It was then I discovered the broken screen. Damn.
    Aug 01, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
    LCD screen wont work
    I had this problem w/ my canon. It is a cracked LCD screen. I took the camera apart and replaced the LCD screen. I ordered the new one for $50 including shipping. you may have to do some detective work to find the part you need. I used a screwdriver for eyeglasses.
    Mar 27, 2008 | Fuji FinePix A600 Digital Camera
    BROKEN LCD
    Hi.
    Jeez! You posted this in January! I wonder if this is even still an issue for you.
    Well, what you DON'T do is take out absolutely every screw you can see and then pull the damn thing apart, nearly rendering it useless -- like someone I know nearly did....
    I can only help you as far as getting the LCD off/exposed. I dropped my camera the other day and discovered my cracked LCD screen.
    You say you've taken all 6 screws out. That's good. There are two MAIN (sort of hidden) screws on the bottom of the LCD screen itself -- these hold the frame of the LCD to the shell into which the frame fits. If you look closely at the LCD screen, you'll see there's a plastic frame around it. This is actually sunken into an outer shell which encases it.
    Turn the LCD screen around so that the glass faces outward and fold it flat against the camera -- LCD facing outward instead of inward (the silver Panasonic logo should be against the camera body). Now you have a flat surface to work with.
    The whole LCD screen mechanism is sandwiched around the pivot point. I took two flat blade eyeglass screwdrivers (you know, the real small kind) and started prying at the pivot point. As you work one bigger flat blade into the pivot point and pry up, use the other screw driver to keep the plastic frame still pryed up in place while you reposition the other screwdriver, continuing to "walk" the screwdrivers carefully around the perimeter of the frame. It won't be too long before you'll see that just off of each corner of this plastic frame there are small tabs which should easily pry away from the plastic "Panasonic logo" shell.
    The LCD then sort of pops out of the shell and dangles by a ribbon connector.
    I don't have any clue where to go from there, tho. I haven't purchased a replacement screen yet.
    May I ask: Where did you buy your replacement LCD from? Do you know how to reattach a new one?
    I hope this helped.
    Thanks in advance!
    danmillen (at) hotmail (dot) com
    Jan 21, 2008 | Panasonic PV-GS39 Mini DV Digital...
    Crack screen
    hi jenla,
    Sharp televisions have a few layers of plastic before getting to the actual screen, these are very cheap to replace, and they just require you to take the cracked one out and replace it.
    However, if the picture is affected, then it will cost alot to replace the screen, hopefully you have warrenty, you may want to replace the tv itself
    Dec 31, 2007 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
    Sony Ericsson Cyber-shot C905 Cell Phone Logo
    281 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
