Sounds like the heating element has gone bad I would call a repair man to fix. But it can be done yourself if you know how to take the housing off. Replace wire element the was the old one was on.
Gas or electric? If gas check for flame. If electric check the heater element. Go online and get a replacement. Doesn't really matter which watts you get. Should always run dryer on low setting and let the air do the work not the heat. Check the air vent and clean as necessary. You can save energy by doing loads and then adding wet clothes to dry clothes. Break up the wash load into managable sizes. Let me know.S
Hello there and thank you for choosing fixya This is a fairly common problem with gas dryers there are several components that need to be checked thoroughly i will list them here below ok? Quick
Gas Dryer Tips:
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling
on and off but never lets the gas go. Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all, Answer ( most common ) -
Inspect igniter for small burnt spot on dark gray or black part of
igniter or check for 110 volts to igniter when dryer should be calling
for heat. On the back of the dryer
near the fan blower housing is a thermal
fuse, if this opens up ( no continuity
) the gas burner often quits but the motor will still run. If the thermal fuse
is open/bad, always clean, change, adjust the venting system and vent hood first
and clean out the dryers air ducts. Sometimes it is a good idea to replace the
operating thermostat at the same time. Thermal
fuse parts help link...on blower housing cover, can not be re-set, must be replaced
if is open (no continuity between pins).
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
pull the vent line off the back of dryer and see if it helps,also the duct that the lint filter slides into could be loaded with lint,when was the last time you cleaned out the dryer?sounds like from what you said when you had the top off it worked better because you had better air movement with the top off.go out side and check the vent,if it's a long run from the back of the dryer to the outside vent i use a leaf blower to blow out the vent line,you also need to vac out the inside of dryer where the motor is,if you have a shop vac blow off the motor and blow through the inside vent to clean out the heating duct and vac out the back of the drum,you should take it apart and clean it out once a year so the dryer will run correctly
when was the last time you cleaned it out,try running it with the vent line removed,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac put it on blow and blow off the motor and clean out the vent line and the outside vent,if the vent line is long i use a leaf blower to clean out the vent line,also is it gas or electric?next time send model number?if it's gas you could have bad gas coils,when they heat up they fail,clothes are warm at end of cycle.run the dryer for 15 to 30 minutes and check to see if the flame is still lighting if not bad gas coils.hope this helps
when did you last clean out the dryer?you have to clean out the vent line if it's a long run i use a leaf blower to blow out the vent line to clean it,unplug the dryer and clean out the duct that the lint filter slides into and vac out the inside where the motor is,this should be done once a year,also if it's gas you could have bad gas coils,when the coils heat up they shut down if they are failing,run the dryer for 15 to 30 minutes and check to see if the flame is still liting,if it isn't change out the gas coils but still do the clean out no matter what
Remove the vent from the rear of the dryer.
With no clothes in the dryer and the dryer set for hi heat run the dryer several minutes.
With a accurate thermometer check the exhaust vent temperature.
It should be 135 to 160 degrees.
If it is, you are OK. Just need to clean your vent and connecting tubing.
If not, replace your gas valve coils.
