Question about Garden
WHAT IS THE FUEL MIXTURE FOR THE POULAN S25A CHAINSAW
    Sergeant:
  • 353 Answers
40:1
Posted on Jun 27, 2009
My poulan chainsaw,the cilinder gets oil,so the sparkplug gets wet and it will not start
Probably have a Carb. problem. Take the carb apart and clean. The Needle Valve sounds like it is sticking.
Jan 18, 2013 | Poulan Garden
What do theT H L adjustment screws mean
These are the fuel adjustment screws, the L screw will adjust the fuel mixture from idle to half throttle, the H screw will adjust the fuel mixture from half throttle to maximum throttle, this will also control the maximum revs, the T screw is the tick over or idle adjust screw
Oct 12, 2011 | Poulan 18" Wild Thing Chainsaw
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
Fuel mixture settings
The fuel mixture for that saw is 40:1. Please give a Rating if this has been of any help. Have a Great Day.
Apr 02, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a Poulan chainsaw that starts, and runs, but when I squeeze the throttle trigger, it bogs, and stops running. Any suggestions as to the problem?
The possibilites are 1. dirt or water in the fuel; 2. filter in fuel tank clogged; 3. main mixture screw set too lean. I am presuming you have the correct petrol/oil mixture.
Mar 20, 2010 | Poulan Garden
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Poulan 14" Chainsaw-Has no fire.
No. That would have nothing to do with it. Too lean a mixture would have just seized the engine from lack of lubrication. That saw probably is meant to burn 40:1 anyway. 50:1 wouldn't hurt it in that length of time either. Where did you get 16:1 as the mixture? It's been years since anything was made that used that.
May 17, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
