Question about Audiovox PPC 6700
Text message alerts
My phone stopped making any sound when I get text messages or pre set reminders. how can I fix this
    Problem Solver:
  • 10 Answers
Re: text message alerts
I tried assigning several different sounds, with and without vibrations, in the Settings section. It didn't make a difference. I suspect there is a software problem in the operating system. I know a couple of other ppc users with the same problem.
I'll try the link you probided. Thanks!
Posted on Dec 08, 2007
    Problem Solver:
  • 11 Answers
In PhoneStart-->Settings and Sounds&Notifications, you can set each notification sound/light/vibration setting for several different things on the phone.
If you want to disable the message after sending an SMS message, go to :
and install that on your phone for MANY more options. Your SMS message notification disable is the first option on the program!
Posted on Dec 06, 2007
0 characters
3 Points
My text alert will only sound as one thing. I've tried changing notification alerts but nothing works. I just want to change my text message alerts to something different than then basic "ding"...
Hey Carlanoelle!
Here's what you need to do:
  • Open the default messaging app
  • Press the "Menu" on the G1
  • Select "Settings"
  • Scroll down the page until you see "Notifications"
  • Make sure Notifications is checked
  • Select "Notification settings"
  • "Select Ringtone"
Mar 07, 2011 | HTC G1
My HTC Touch Cruise (09) will not stop vibrating every time received a text message, unless I send a reply to that message. The alert tone for sms has also stopped functioning, even though I have the phone...
Please turn off your phone for 5-10 minutes and then turn it on and then try to change the settings for your alerts.
Hope this will work for you.
May 17, 2010 | HTC Touch Cruise Smartphone
How do you make the text alert beep/ring more than once? when you get a text and you don't check it right away, that it will go off again to remind you you have a new message
the blackjack 2 does not have that catability to do that but you can change the way it alerts you from the settings menu in the sounds folder hope this was helpful:)
Oct 13, 2009 | Samsung BlackJack II Smartphone
Because in message settings below alert option you have selected vibrate only select sound and vibrate option you will get your sound
Jun 14, 2009 | HTC G1
Can't seem to text
Do you have the message center number that it's sent through.. Go to menu, messages, settings, and text message and see if this number works. +13123149810
Apr 23, 2009 | Samsung BlackJack II Smartphone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using!
Try the following instructions, to personalize your Nokia E50!
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info!
Feb 15, 2009 | Nokia E50
Message alerts aren't working
Make sure that you have text notifications set on in the preferences section of your message options. You may have to do a reset on your device because sometimes script errors occur on the phones and causes simple things like that to stop working. Also, check to make sure that you have version 1.07 on your phone. That is the most updated version which addresses many script issues, networking issues, and volume issues, along with improved security.
Dec 18, 2008 | Palm Treo 500 Centro
Text message ringtone
u have to change the alert that you set as your ringtone, that's the only way to stop it. So try it and see if that works
Oct 30, 2008 | T-Mobile Dash Smartphone
Sms alert
Jun 07, 2008 | LG KU990 Viewty
Text Message alert???
In order to use tones other than the presets for text messages, you have to put new .WAV files on your phone. Any 8bit .WAV file will work; just connect with ActiveSync and navigate to your /Windows directory on your phone, and place the files there. You will then be able to use them as text message alert tones.
Aug 29, 2007 | Audiovox PPC 6700
Audiovox PPC 6700 Logo
77 people viewed this question
Top Audiovox PDAs Experts
Martin Murray
Starnley Johnwells
Starnley Johnwells
Are you an Audiovox PDA Expert? Answer questions, earn points and help others
