Question about Emerson Quiet Kool 10GV13 Air Conditioner
Removing front panel from Emerson Queit Kool A/C
I have a through-the-wall Emerson Quiet Kool A/C that came with the apartment we moved into. The control knobs work but the metal plate listing the control settings (Off, Hi Fan, Low Fan, Hi Cool, Low Cool) for the Master Control and 1-10 for the Thermostat) has fallen off, so you have to turn the knobs blindly. How do you get the front plastic panel off so I can put back the metal plate with the markings (and then pop the knobs over it?) Thanks,
Jerry Vanderberg
ACTECH
  • 80 Answers
SOURCE: Emerson Quiet Kool A/C Filter
YOU CAN GET THE FILTER MATERIAL FROM ANY HOME DEPOT OR LOWES AND CUT IT TO FIT YOURSELF. JUST BRING A SAMPLE OF THE MATERIAL WITH YOU AND GIVE IT TO THE SALES ASSOCIATE
Posted on Dec 07, 2007
ACTECH
  • 80 Answers
SOURCE: Need new filter for Emerson Quiet Kool
GO TO HOME DEPOT AND BUY A CUT TO FIT FOAM FILTER FROM THEM IT IS THE SAME MATERIAL AND COSTS ALOT LESS BRING YOUR OLD ONE WITH YOU SO THEY CAN HELP YOU FIND THE RIGHT ONE. IF YOU WANT AN OEM FILTER I NEED THE MAKE AND MODEL# TO HELP YOU
Posted on Jan 14, 2008
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
beverleyed@yahoo.com
Thanks
Ed Beverley
Posted on Jul 07, 2008
  • 24 Answers
SOURCE: BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
Posted on May 27, 2009
koolbreezes
  • 540 Answers
SOURCE: I need a replacement front panel for an Emerson
Type in the brand name, go to the website, and type in all the model#,s and surf..
Posted on Dec 08, 2009
I need to remove the blower motor from my Emerson Quiet Kool model 1350, how do I do this..
First open the control panel and remove all wires of your fan motor from the control switch and the capacitor. Remove also the compressor wires. Unscrew all panels and move the evaporator farther from the mounting base Pull-out the fan motor assembly with the panels. Unscrew the blower, fan blade, and them from the assembly. Unscrew the motor and now it is free.
Aug 31, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
Replacement for Emerson Quiet Kool 12jw42k
Oh yes,there are plenty to choose from,you can go larger,if it is a 220 volt,and get better service,it will cool better,and cost less,on electric.
May 28, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
Hello, i have a thru the wall Emmerson Quiet Kool ac that is only 1+ yrs old. I need a tech support. Who in zip code 10805 could I call?
Any HVAC contractor should be able to help you. First thing to check, though, would be the filter on the front. These units pull air in and a filter helps keep the dust out of the cooling coil. After a year or so, the filters can get clogged which stops the air from moving, and so they don't cool very well. If you clean your filter every spring, your unit will work much better, and it's a simple matter to open the front cover and wash it out. Let it dry before you put it back. If it still doesn't cool, then it's time to call the tech.
Aug 26, 2009 | Emerson Quiet Kool 10NW16K Air Conditioner
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Air Conditioner #10HW42K through wall
First off, my model # is Emerson Quiet Kool 10HW42K. No it is not yet solved, however I am reaching out to a number of sources. Was hoping to get a simple answer since it is not a "repair" problem, but rather a "replacement problem". I am looking for another AC that will fit the original sleeve.
Jul 07, 2008 | Emerson Quiet Kool 10NW16K Air Conditioner
Thanks
Ed Beverley
Jun 07, 2008 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to eyg2181@yahoo.com
Jul 31, 2007 | Emerson Quiet Kool 14LW22K Air Conditioner
Emerson Quiet Kool 10GV13 Air Conditioner Logo
113 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
