Question about HP Pavilion dv9005us Notebook
My HP Pavilion dv9005us has two issues which I cannot resolve. The wireless device is not even recognized or detected by the computer, and there seems to be an electrical problem where the lighted buttons at the top flicker on and off from time to time, which may also be linked to an issue where the computer will at times refuse to turn on after I press the on button and watch it all light up in response and immediately shut off. Any help with this would be greatly appreciated.
  • 788 Answers
Sorry to here about your DV9005us start up problems.
1st. It would be good to know any other problems you may have had in the past either related or non related to you current problems..
2nd. Has the unit been dropped ?
3rd. The 6000 - 9000 series units are all pretty much the same as fare as board layout.
The top Led's and connected by a small flat ribbon cable. This cable is a 12 pin piece of junk, which you have two in your unit.
Both are located on the bottom left under keyboard. At that connection point the cables push in and are in most cases a solid connection. However, they connect to the Push button - Led Strip directly above the keyboard and at those two connections, HP uses a clamp or push down connection.
For years I have seen the similar problems with the Led's flashing on the Led strip.
Also, you have said the unit at times does not power on, I would be willing to bet, that is why.
One of the 12 pin cables controls the Power startup button, the other feed display information and touch since controls.
Ok, you must decide if you want to take on the repair yourself, or have it done by a technician ? If you interested in doing this repair yourself, you will need to (A) remove any media from the unit along with the battery.
(B) Remove all of the fallowing parts and keep in a static free, dry place, away from your work and tools.
(C) Remove the two plastic covers underneath, covering the memory and Hard Drive.
(D) Remove the Hard Drive and set in safe place. Remove the memory and do the same.
Note... Just to the right above the memory is the CMOS battery (2 pin) Red and Black leads. Disconnect where connector meets the board.
(E) With the unit on its back and the battery compartment at the top, remove the first row of screws (6) set them aside.
(F) Now, in the battery compartment, you will see (3) silver screws, remove them.
Note... You do not have to remove any other screws at this point on the bottom of the unit.
The remaining screws are for the keyboard, which we will leave in place and the DVD drive.
(G) next you will want to flip unit over and firmly with both hands grasp the Led cover or strip and lift up.
Note... This Led panel is connected in (3) places. 1 and 2 are the ribbon connections, the third (3) is your sound connection (4 pin).
(H) Once the Led panel is loose, stop the Led panel should be able to fold over the keyboard, revealing the (3) connection points.
Note... These connection points are very delicate and easy to break. So be carefully.!!
(I) It may be a little easier if you disconnect the (4) pin sound connection. This will give you a little more run and flexibility.
(J) At this pint you can lift the gray plastic tabs a few mm and re-secure the two flat cables.
Note.... These cables are very easy to damage, so handle with care.
You may want to reseat one at a time, remembering these flat cables need to be completely seated.
After you have reseated connections and reinstalled Black (4pin) connector, fit Led panel back. Note. you will here it snap into place. Hold down the power button for 15-30 seconds. This will clear the CMOS.
(H) Flip unit over, re-install the hard drive and (1) piece of memory.
Install the cover for the Hard drive compartment.
(I) re-connect the CMOS battery.
(J) install (3) silver screws in battery compartment. The remainder of the screws can wait until you have finished.
Install battery.
(K) Flip unit over and connect to power source.
Now this time I want you to touch the Led strip. The strip should bring uo the unit in Quick Play, (unless you have deleted it.??
See if the Led's are still blinking ??
The unit should come into the BIOS screen asking you for the time and date.
Note.... If you can stay in this BIOS screen without shouting down, and the Led's are not blinking, you’ve done it...
After setting the date and time, you may want to power down the unit, flip it over and replace removed screws.
If you are smart, you will run over to HP.com and download and FLASH your BIOS to current date.
Please make sure the unit is working 99% before updating the BIOS. While flashing the BIOS, Do NOT TURN OFF UNIT.
PLEASE LET ME KNOW IF ALL OF THIS WAS JUST A WAIST OF TIME.
Reader, please rate this information, weather you agree or disagree, it lets the technician who is typeing this information,(one key at a time) it was worth the effort.
Hope this information find your computer in good to better health..
John Ray
john@johnrraycomputer.com
Posted on Jun 29, 2009
Dv9005us mother board.
Laptop do not have the capability of a desktop computers that allow you to install various motherboards inside the PC case.
You can improve the performance by installing more RAM and replacing the hard disk with a solid state hard disk.
Dec 14, 2012 | HP Pavilion dv9005us Notebook
I have hp dv9005us and all of a sudden it wont acknowledge the wireless networks. it goes straight to the ethernet. and the wireless color stays on red, (when its suppose to be blue) in the front of the...
Perhaps the wireless drivers got missing. Try download another: Goto google search and type "hp dv9005us wlan drivers.exe download" you'll be redirected
Aug 05, 2017 | HP Pavilion dv9005us Notebook
Dv9005us will not power up
Please use these instructions from HP or this article to help troubleshoot this startup problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 06, 2009 | HP Pavilion dv9005us Notebook
WLAN not being detected in HP Pavilion tx1210 laptop
first of all is the wireless adaptor recognized under the device manager?
no, you need a new mini pci wireless lan card
yes, the wrong driver is installed, the windows utility is not enabled
Mar 02, 2009 | HP Pavilion tx1000z Notebook
Hp pavilion dv9005us NO sound problem
you may want to check to see if the speaker wire is connected to the audio board. You'll need to remove the Keyboard, palm rest, etc. It should be located toward the front of the LT.
Jan 06, 2008 | HP Pavilion dv9000z Notebook
DV9005US - No post All leds on No beeps
my suggestion you bring that to the service center for the expert operation because all part of your laptop is highly sensitive with the electro static that will cause for the damages of some component..
Dec 15, 2007 | HP Pavilion dv9005us Notebook
I need a new motherboard for dv9005us
hi can you click this site..........
http://search.ebay.com/search/search.dll?ht=1&from=R4&satitle=+dv9005us&sacat=58058%26catref%3DC6
Dec 13, 2007 | HP Pavilion dv9005us Notebook
Wireless connection no longer works after vista upgrade
HP uses "branded" wireless modules,which means it's got to be HP or it doesn't get to play.
Does device manager see the wireless device? I've had similar situations with the 8000s. Always the driver or the wireless utility was the problem. Try letting windows manage the device, or if you already are, disable that and use the devices utiliy to manage it.
BTW, most systems consider BT as wireless.
Good luck, hope that helps
Nov 25, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion dv9005us Notebook Logo
646 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
