Question about Frigidaire Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
IDry Frigidaire Affinity Front Loading Gas Dryer.
In about 5 minutes of starting the dryer, an error "Ad" shows
in the window above the start button. Then the dryer stops and the lights under the "Ad" window above the "start" button flash -
(drying, cool down, extended tumble)
Our Dryer is fairly new, all lines and vents are kept very clean on an ongoing basis, gas is hooked up properly.
Thank you in advance for your expertise and your time!!
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
Affinity 6000 es1 error code ad
Good Afternoon Friend,
I understand that your Frigidaire washer, model# ATF6000ES1, is displaying an "AD" code. The "AD" means that your appliance was in an automatic mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Ad error code
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Frigidaire Affinity Front Loading Electric Dryer. In about 5 minutes of starting the dryer, an error "Ad" shows in the window above the start button. Then the dryer stops and the lights under the "Ad"
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Mar 04, 2013 | Frigidaire AEQ7000ES Dryer
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity dryer model FAQE7001LW0 OVERHEATS AND SHUTS DOWN
Therm o resistor or air ducts venting needs clean out
if not that change main board
Aug 13, 2012 | Frigidaire Affinity FAQE7001LW Electric...
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire  Electric Dryer Logo
1,312 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
