Question about Kenmore Sewing Machines
Feed dogs are not pulling the material back - Kenmore Sewing Machines
  • s_jawanda Jun 27, 2009
    Hi, i have checked all of that...feed dog switch is in up position and stitch length is at 2.5....it was working fine and then all of the sudden it stopped pulling the material back. It is a Kenmore 385.15212
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Posted on Dec 11, 2009
  • 208 Answers
Make sure that the feed dog switch is in the up position. Make sure that the presser foot pressure is at the maximum. Make sure that the stitch length is set above 0 or 1 (normal stitch length is about 2.5)
If this doesn't help, let me know your brand and model number.
Posted on Jun 27, 2009
  • Paul Howell
    Paul Howell Jun 28, 2009
    First turn the pattern selector to different patterns running the machine a
    little with the different stitches observing the movement of the needle
    and feed to see if the machine is in sync.
    Then observe the feed dogs to ensure that they are coming up and not loose or touching the slots in the needle plate.
    Try removing the bobbin case and unthreading the machine. Then remove the presser foot and place the lifter in the up position. Remove the needle and securely tighten the needle clamp screw. Set the stitch length to maximum and run the machine at a moderate speed alternating in forward and reverse for a few minutes. Try different patterns, running a few to see if it will loosen up.
    Rethread and retry.
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
SOURCE: Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Posted on Jan 15, 2009
  • 11 Answers
SOURCE: Feed Dog problem
I listened to all that...and none of it worked...so I took the plate off and gave it a good clean. Still nothing. If your machine's a bit old like mine or tends to get stuck...physically lift up the feed dog with your fingernail or a flat screw driver or something (once the plate is off), then push the feed dog lever across and release the feed dog. It should hold in place if nothing else has worked...woo!!! :)
Posted on Feb 18, 2009
Janome Machine will not feed material !!
If the fabric is not feeding, the feed dogs are probably not operating properly. Check that they have not been dropped below the needle plate (which is done when darning or free motion quilting). In this setting, the feed dogs never rise above the needle plate to grab and pull the fabric.
The other issue could be that the feed dogs are defective or perhaps seized.
Since you did not provide a model, I can provide only this assistance. It would be helpful to locate (search for make model manual) for your machine.
Dec 30, 2016 | Janome Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
How do i get the material to feed through
depending on the brand of sewing machine you have, make sure it's not in the darn mode,, make sure the presser foot is against the fabric so the feed dogs can pull it thru,,if the presser foot is against the fabric correctly then the feed dogs may need to be check to see if they need a adjustment or replacing
Dec 02, 2014 | Sewing Machines
Singer sewing machine 1030 feed dog will not pull material in
try using maximum stitch length, if still not working try removing needle plate and clean you teeth
Feb 18, 2014 | Sewing Machines
Machine won't feed material. I have to pull while sewing.
First of all stop pulling that will only bend your needle and cause further problems.
Check to make sure your feed dogs are engaged. There should be a switch somewhere around the sewing area front or back or perhaps under a flat bed attachment.
Oct 28, 2012 | Singer 4423 Sewing Machine
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
Aug 24, 2006 | Janome 405 Mechanical Sewing Machine
Sewing Machines Logo
894 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
