How do you install this update without the pc crashing..it happen before and did have to do a clean reeinstall of vista
  • frenchy47 Jun 27, 2009
    Hello Eske..Me again....
    I have a program called "detective driver " which find update for the Asus motherboard driver and it found one "Nvidia nForce serialATA controller" which is a chipset driver..
    I did try before to update it but my pc crashed and did have to do a clean reinstall of vista..I do not want the same thing happenning..may the last time I did something wrong in the process so i would like tp know how to get ready to be sure it does not happen again...
    thanks
  • 13,433 Answers
Which update? can you clarify the question?
Posted on Jun 27, 2009
  • Ekse Jun 27, 2009
    Driver Detective... well the past 10 years I've never used any driver detective program and my computers work well.
    There are no major changes done in device drivers, unless you have a problem with your computer then you should consider checking for updated drivers, but certainly a "Nvidia nForce serialATA controller" which controls the hard drive, the driver should not be updated unless the machine is not working.
    The machine is working so please don't update the driver.
    Please stop paying for driver detective, it doesn't actually do much good.
  • Ekse Jun 27, 2009
    well I installed driver detective to my computer, its telling I have 7 out of date drivers, but my computer works perfectly - theres no need to upgrade the drivers if everything you do with the computer is working.
Satellite PSAGCA-06M01N keeps restarting when i try to upgrade windows
Computer randomly restarts is not something unique happened to you. Sometimes there is a dreadful total crash of the system and sometime it sends different errors, upon restarting nothing happens.
-- First of all disable the auto-restart option from your control panel settings
-- Remove any recently installed maliciously software/add-on or any other application or toolbar.
-- Try to cool down your PC as the overheating due to overuse of computer may result in system freezing and sudden restarting.
-- Update your BIOS.
-- Update the drivers
-- Make it sure the error is not caused by the deficient power supply. You may try to change the power supply.
-- Conduct the registry clean up scan for quick fix of the problem.
-- Remove flashy games and/or untrusted antiviruses/antispywares. Conduct the security scan through the most powerful scanners only.
I would recommend to use a system utility tool like PCFresher to fix windows errors and registry errors. Then try updating hope problem is fixed.
Apr 29, 2012 | Computers & Internet
Reinstall factory settings using Functions keys on a toshiba
Without a re-install disk, you are unable to re-install windows. The function key is most likely F2 or F10, 11, or 12. It is also possible that it could be the delete button.
Apr 22, 2012 | Dell Inspiron 700M Notebook
Everytime I do a windows update, it either crashes or hangs on "shutting down" (after leaving it on all night!). Then I lose everything. Help!
you have to be more spacific on what you are doing and what os you are using. Are you using Windows 7 or Vista. If you are using vista, Dont. upgrade to windows 7, it's worth it. but everything else aside, try different ways of installing the updates. you can download the updates manually and install them other then just letting automatic updates do everything.
May 09, 2011 | Acer Extensa EX4420-5239 Notebook
I can run skype on audio but when i use video it crashes after about 3 min. I installed sp 2 for vista and reinstalled skype but it is still happening.Can you help? Thank you
check for video driver, update ur video driver and checl preferences of skype and run registry cleaner reg in out to fix the issue
Sep 06, 2010 | Acer Aspire 6920 Notebook PC
I have a compaq presario laptop with windows vista, 2 weeks ago it was working fine and now it loads up fine but crashes everytime i try something, what can i do appart from wiping off and starting again
Hi. I think the best to resolve this issue is to restore again your system to its factory settings or reformat again your system, then after doing it you should disable the automatic updates from the control panel so that you're system would not automatically update itself, because most of the time Vista crashes because the updates it made and sometimes you tend to shutdown your system without finishing the updates from microsoft then it would cause that crash the next time you open up your system. To disable the automatic updates just go to control then click classic view on the upper left side then look for the Windows Update icon on the control panel, and from ther just turn off the automatic updates. I would also suggest that if you to maintain the automatic update you should make sure that the updates are already finish before you shutdown your computer or you could change the schedule of the updates depends on what date have you chosen. Hope This Helps
Jun 03, 2010 | Compaq Presario 700 470024-192 Notebook
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
Apr 03, 2010 | Dell Inspiron 1525 Notebook
Google Earth crashes on my Acer Aspire
it will require a grafics update or try to go in windows update and manual check for updates and see opcional updates please thanks
Nov 05, 2009 | Computers & Internet
Mic keeps crahing computer
In case your settings change involved installing a new driver try rolling it back. If your pc was upgraded from xp to vista the drivers for the sound card may need to be updated.
Feb 19, 2009 | ASUS M2N-E SLi Motherboard
Fatal Error installing HP 6210 All-in-One on HP (!) Vista Desktop PC
If you do a new, clean install of Vista in 2018, one would be missing hundreds of updates from Microsoft that would be very hard if not impossible to get. Some of those updates might apply to software that you want to use in conjunction with Windows Vista. And if it is an older PC, you might not be able to find driver support for the particular make/model, and Vista might not have the drivers you need. How many times have you heard someone say, "I just reinstalled Vista, but now I am missing drivers?"
This could be your trouble, because even if your Vista updated all the way up to April 2017, you could still be missing HP updates provided by HP/Microsoft through Windows Update.
Since Microsoft has not supported Vista since April 2017, I would recommend not using it anymore in 2018.
Jan 18, 2018 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
