Question about Motorola Mobility ROKR E6 Smartphone
How to install theme in rocker e-6
Hi, i m not able to install theme in my rocker e-6
Posted on Jun 29, 2009
How to install rocker arms on a Pontiac grand am 2001 V-6
Hi there:
Rocker Arms & Pushrods
Removal & Installation
3.1L & 3.4L Engines
Left Side
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system to a level below the coolant pipe on the front of the engine.
  3. Remove or disconnect the following:
    NOTEKeep the pushrods in order. Intake pushrods are 5 3 / 4 inches long and exhaust pushrods are 6 inches long.
    Negative battery cableSpark plug wiresHeater bypass pipePositive Crankcase Ventilation (PCV) valve and hoseRocker arm cover
    Rocker arms and pushrods
To install:
  1. Lubricate all the valvetrain components with engine oil.
  2. Install or connect the following:
    Pushrods and the rocker arms. Torque the bolts to 24 ft. lbs. (32 Nm).Rocker arm cover using a new gasket. Torque the rocker cover bolts to 89 inch lbs. (10 Nm).PCV valve and hoseHeater bypass pipe. Torque the screw at the water pump to 106 inch lbs. (12 Nm), the bolt at the cylinder head corner to 18 ft. lbs. (25 Nm) and the nut to 18 ft. lbs. (25 Nm).Spark plug wiresNegative battery cable
  3. Refill the cooling system.
  4. Start the vehicle and verify no leaks.
Right Side
  2. Remove or disconnect the following:
    Negative battery cableAlternator bracket on 2005 modelsSpark plug wires from the spark plugs and the upper intake plenum wire retainerPower brake booster vacuum pipe from the intake plenumAccessory drive beltAlternator, if necessaryIgnition coil assembly and Evaporative Emissions (EVAP) canister purge solenoid as an assemblyRocker arm cover
To install:
    Pushrods and the rocker arms. Torque the bolts to 24 ft. lbs. (32 Nm) plus an additional 30 degree turn.Rocker arm cover using a new gasket. Torque the rocker cover bolts to 89 inch lbs. (10 Nm).Ignition coil and EVAP solenoid assemblyAlternator, if removed. Torque the bolts to 37 ft. lbs. (50 Nm).Accessory drive beltPower brake booster vacuum pipe to the plenumSpark plug wiresNegative battery cable
  3. Start the vehicle and verify no leaks.
Hope this helps.
Mar 04, 2013 | Cars & Trucks
Tip
How to Add a Theme / Change Icons on your iPhone / iPad in iOS 7
I. Jailbreak your iPhone/iPad
To do this procedure you must be jailbroken. If you aren't, you can head to our Jailbreak How To's section and pick the jailbreak for your version of iOS (currently at the time of writing this is 7.0.4). Once done with that procedure and you have Cydia installed, head back here to continue.
*Don't be scared, it's easy to unjailbreak your device.
II. Install Winterboard
1. Open Cydia (if it isn't still open from the section above).
2. Tap Search in the bottom right corner.
3. Type in Winterboard.
4. Tap on Winterboard when it shows up.
5. Tap Install in the top right corner.
6. Tap Restart.
III. Use Winterboard
1. Open Cydia.
2. Search Cydia (either by searching using the search tab on the bottom right, or by tapping the section tab and then Themes (Springboard/Winterboard) icon).
3. Once you find the Theme you want and it says it's compatible with iOS 7, tap Install.
4. Tap Return to Cydia.
5. Open Winterboard.
6. Tap on Themes.
7. Select the theme you want to use.
8. Tap the home button and wait for it to respring the device
9. Repeat steps 1-8 to apply a different theme.
IV. Revert to the Original Apple Theme
1. Open Cydia.
2. Tap on Manage.
3. Tap on Packages.
4. Tap on Winterboard.
5. Tap Modify.
6. Tap Remove.
7. Tap Restart.
on Nov 21, 2014 | Cell Phones
How to lnstall a psp ctf file
Hi
1. Download the plugin
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
7. Also notice that you will at least need PSP FIRMWARE 3.90 OR HIGHER to be installed on your PSP in order to get these themes running... Or see the video
http://www.google.co.in/search?q=to+install+a+psp+ctf+file&hl=en&safe=off&sa=G&prmd=ivns&source=univ&tbs=vid:1&tbo=u&ei=L2YxTf_TCIzEvgObvpSqCw&oi=video_result_group&ct=title&resnum=4&ved=0CCIQqwQwAw
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
See the video
Jan 15, 2011 | HP Computers & Internet
How should i install vista theme through net
i want free windows vista theme for xp... how to apply the theme
Aug 27, 2009 | Microsoft Windows Vista Ultimate Edition
Install desktop theme
Hi there! Here's a solution to your problem. If you're using Vista WITHOUT SP1, Step 1: Download the UxTheme Patch from here. http://www.softpedia.com/get/System/OS-Enhancements/UxTheme-Patcher-for-Windows-Vista.shtml If you're using Vista WITH SP1, Step 1: Download the UxTheme Patch from here. http://www.softpedia.com/get/System/OS-Enhancements/UxTheme-Patch-for-Windows-Vista-SP1.shtml Step 2: Login as a user with Administrative privileges -or- have Administrative credentials ready (check under the keyboard for a slip of paper). Step 3: Navigate to %systemroot%\System32 Step 4: Right-click uxtheme.dll and click properties. Step 5: Take ownership of the file and close dialogs. Step 6: Repeat steps 3 and 4 for themeui.dll and shsvcs.dll Step 7: Right-click uxtheme.dll and click properties. Step 8: Give yourself (or group) Full Control permissions and close dialogs. Step 9: Repeat steps 6 and 7 for themeui.dll and shsvcs.dll. Step 10: Rename uxtheme.dll to uxtheme.old. Step 11: Rename themeui.dll to themeui.old. Step 12: Rename shsvcs.dll to shsvcs.old. Step 13: Copy patched files into %systemroot%\System32 Step 14: Reboot After you have applied the patch, you can copy the theme into your Windows/Resources/Themes folder!
Jun 13, 2009 | Microsoft Windows Vista Ultimate Edition
Changing Camshaft seal
1. Install the camshaft after lubricating the journal of the camshaft with engine oil. 2. Install the camshaft bearing caps.a0b9a5d.jpg
3. Install the ignition coil. 4. Install the rocker arm and rocker arm shaft. Refer to "Rocker Arms and Rocker Arm Shafts" section. 83e48db.jpg 5. Using special tools, Camshaft Oil Seal Installer (09221-21000), press fit the camshaft oil seal. Be sure to apply engine oil to the external surface of the oil seal. Insert the oil seal along the camshaft front end and install by driving the installer with a hammer until the oil seal is pulley seated. bda0592.jpg 6. Install the camshaft sprocket and tighten the bolts to the specified torque. 2cbbe98.jpg
May 05, 2009 | 1996 Hyundai Accent
Player and themes
i dont know how to download themes
Aug 11, 2008 | Motorola Mobility ROKR E6 Smartphone
About installation of themes
Step 1: Download Windows Vista UxTheme patch.
How to install
1. Login as a user with Administrative privileges -or- have Administrative credentials ready (check under the keyboard for a slip of paper).
2. Navigate to %systemroot%\System32
3. Right-click uxtheme.dll and click properties.
4. Take ownership of the file and close dialogs.
5. Repeat steps 3 and 4 for themeui.dll and shsvcs.dll
6. Right-click uxtheme.dll and click properties.
7. Give yourself (or group) Full Control permissions and close dialogs.
8. Repeat steps 6 and 7 for themeui.dll and shsvcs.dll.
9. Rename uxtheme.dll to uxtheme.old.
10. Rename themeui.dll to themeui.old.
11. Rename shsvcs.dll to shsvcs.old.
12. Copy patched files into %systemroot%\System32
13. Reboot
Step 1b: If you find the above too intimidating, download VistaGlazz and just run it, it automates the whole patching process so you don’t have to worry about it!
Step 2: Download a Windows Vista Visual Style from a free Windows Vista Themes gallery, and copy the theme to Windows/Resources/Themes folder.
Step 3: Right click on desktop and click on Personalize. From the page that pops up, click on Theme and choose your newly installed theme!
Jul 13, 2008 | Microsoft Windows Vista Ultimate Edition
Downloading themes for motorokrE6
you can find answers to ur problem on www.modmymoto.com
Mar 15, 2008 | Motorola Mobility ROKR E6 Smartphone
How to install a themes for my motorola L7
first you download motorola skin loader and then you download motorola themes .ski file format, now you connect the mobile into computer and run the motorola skin loder the add the .ski file and install into your motorola l7 mobile phone.
Oct 05, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility ROKR E6 Smartphone Logo
47 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
