Why not leave the original jacks in place, cut the wires near the old speakers and new speakers and just replace the speakers, using 2 scotch lock connectors to connect the 2 wires to each speaker. (Keep polarity consistent for each speaker). Of course you should test one speaker first to make sure they will work with your unit, before you cut any of the remaining wires.You can always connect the originals back as long as there is a bit of slack in the wire.
SOURCE: Pin connections on Spkr out jack
did you every get an answer for this i could use it now [email protected]
SOURCE: My Boston Acoustics BA735 speakers does not fit to my new Dell VISTA PC
As long as you can find a compatible plug that fits, it would not be hard to adapt it...some soldering of course is needed or just connect it using the wires if it came with wires. Just take note of the polarity though.
You don't need a software driver for the speakers.
SOURCE: Are these speakers adaptable with my Compaq Presario PC?
Hello my friend, with regards to your problem first we must check if your currentl audio device is compatible with your speakers. I mean you have a 5.1 speaker then let us check if your audio plugs is also a 5.1 channel in order to accomodate your speaker. else you can istall your speaker in to your currentl audio device but not all speakers were work cause it needs to have the same specs from your speaker to your audion device installed in your computer.you can only use the green, and blue then if you have mic the you could used the pink plugs but for your black plugs in your speaker it cannot be used.
