Question about Kenmore Washing Machines
Let our Experts solve your
''MY KENMORE WASHER MODEL 110
COLD WATER WILL NOT FILL WITH WATER'' However the Hot Water works fine. Is it a hose or valve problem?
Thanks
  • 370 Answers
You need to replace the washers water valve selenoid.
Posted on Jun 27, 2009
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
My Kenmore 110 92587210 Washer is slowly letting water in
The solenoid for the cold water valve has failed in the open position and needs to be replaced. The valve unit is for both hot and cold. It is the item that the water hoses are connected to.
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer wont fill using hot water, cold water works fine
try taking off the hoses and maybe the screens on the washers for the hoses are plugged
Mar 26, 2009 | Kenmore 23822 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 110 washer
if screens on both ends of cold fill hose are clean replaced valve have seen restricted flow even with good flow to valve but be sure screen in valve is pulled and cleaned be sure to reinstall it
Aug 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
96 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
