Question about Frigidaire Washing Machines
New control board, washer beeps 9 times but won't start.
I have a Frigidaire (Electrolux) washer model LTF2140ES. It stopped working with an error code E21, which says ''Replace Control Board''. I replaced the control board, but now with the brand new control board the washer beeps and flashes the Doorlock, Wash, Rinse, Final Spin, and Control leds 9 times, over and over. Pressing any buttons does nothing, and the only way to get the flashing and beeping to stop is to unplug the cord from the electrical outlet. I have been unable to find any documentation about flashing/beeping nine times.
ExHandyman
  • 86 Answers
SOURCE: just finished 2 washes with my Electrolux
Use a compatible fabric softener. The fabric softener not only softens fabric and makes clothes smell nice, but they break down and neutralizes detergents.
Posted on Mar 14, 2010
  • 101 Answers
SOURCE: Lights come on and it beeps
The timer may be stuck, you may have to change the timer.
Posted on May 12, 2008
  • 210 Answers
SOURCE: E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Posted on Jun 03, 2008
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0
back bearings defective,,,should sound like train coming down on track..
Posted on Dec 29, 2008
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2140ESO front load washer won't start. Not responsive to panel button inputs (Spin Speed, Options). Only reponse is three beeps. When I move the basket back and forth, can hear a little...
Electrolux washer LTF2940ES3 STOP SPINNING -- EVERYTHING SEEMS TO BE IN ORDER, I.E. DRAIN, BELT THE TURNS THE DRUM, ETC. MY GUESS IT'S THE CONTROL BOARD. IF SO, IS THIS A PART I CAN REPLACE MYSELF?
Dec 26, 2008 | Washing Machines
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Machine keeps doing one step of cycle and beeps
Hi there.
There may be a problem on the control board (you suspected yes?)
Or it may be waiting for a certain condition.
Basically it's a very simple computer.....-
Select program (sequence of events)
Water fills.....Untill weight sensor says stop.
Water then heats........Untill temperature sensor says stop.
Goes through a sequence of motor spins....untill time out.
Pumps out.....untill floatswitch says empty.
Does same again ...or something else.
Either the control board has a fault - so just doesn't advance, or there is a faulty sensor that never supplies the info needed to advance.
Try and spot at what point it stops and waits. This will pinpoint what it's waiting for.
If it's waiting to heat up - and the element has blown. it will be stone cold. This is a common fault.
Let me know how you get on.
Richie.
Jun 14, 2008 | Washing Machines
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
