Question about Ruud UAMB Air Conditioner
Could the low voltage at the unit be a bad
Condenser buzzing, but fan won't turn on.
Could the low voltage at the unit be a bad fuse(s)? we will change the fuses and if that doesn't work I will post again.
  • clbranco Jun 27, 2009
    Wow. we did have a huge lightning storm last nite. It turned out the circuit breaker. it was tripped just a little. when i turned it on the fan started right up. the buzzing was confusing me because I thought if the circuit breaker was off there would be no power for any buzzing at all. thanks for your help
  • 34 Answers
I am presuming you are talking about low voltage at the motor. The fan and condenser use capacitor assist to start them. They can be damaged by a really bad lightning storm or they can just go bad. Difficult to determine why. If you are seeing a low voltage at the motor the capacitor has most probably failed. Check for a device that looks like a thin tin can with wires on top. Get the numbers off the side and you can find a replacement.
REMOVE ALL POWER before playing with the capacitors, they store energy and can kill!!
There may be 2 caps, one for the condenser, and one for the fan. If the condenser runs for a couple of minutes and then shuts down it is probably just the fan. Easy way to check is if the coils get really hot. If it short cycles there could be a different problem. But I would venture to say it is probably the cap for the fan.
If this helped please rate my solution.
Posted on Jun 27, 2009
  • jdaniher
    jdaniher Jun 27, 2009
I have a Coleman mach 3 ac unit. ive replaced everything except the compressor. the fan will come on but when i put it on ac it blows the fuse in the thermostat.
Fuse in the tstat?? First inspect the low voltage wire outside for imperfections, such as bare wires. Unhook the low voltage wires to condenser outside and cap with existing wire nuts. Then replace fuse and turn system on with cooling. If fuse still good then you have a short in the contactor coil in the condenser. Need new contactor. If fuse only blows when a call for cooling it's in the wire for low voltage or the contactor itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 21, 2017 | Coleman Heating & Cooling
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
Goodman GSC130421ab has no voltage to contact after washing coils....it worked just before powering off unit at diconnect to clean the condenser coils
very posisble.check the fuse on the board on the indor unit. replace with equal size fuse (not bigger probably 3 amp). if the indoor unit comes on then the fuse is fine and i would suspect the coil on the contactor has shorted
Oct 02, 2012 | Goodman CKL36AR36 Air Conditioner
We have a Coleman Evcon air conditioning unit model brcs036b and we cannot get it to turn on nor can we find if there are any fuses. the heater works but the actual fan motor for the air conditioner...
Check your stat. is it set properly on cooling, and low enough to turn the unit on, with power on and the stat calling for cooling you should at least get the fan and the out door to kick on, if not your stat or the transformer could be bad. there is a reset on the transf. on some of the unit that could be tripped
Jul 04, 2011 | Heating & Cooling
Randy2465@yahoo.comwhen you turn setting on thermostat to cool the thermostat clicks but outside unit and the inside fan neither come on?
Sounds like you might have a low voltage short possibly at contactor at outside unit (Condenser).
What happens is if your contactor has a short it will pop a 3 or 5 amp fuse at the furnace circuit board. This fuse will continue to pop until the short is fixed the best way I have found is to take off all low voltage wiring at furnace circuit board put them back one by one first with R then W then G then Y if it pops at Y your contactor has to be replaced.
May 11, 2011 | Goodman Heating & Cooling
Thermostat wires dead
If you have a split system (an air handler that blows air into your house and an outdoor unit that has the compressor and condenser coil/fan), then you should look in the electrical compartment of your indoor unit and see if you can locate a low voltage fuse. This is usually located on the control board or between the transformer and "R". Make sure you shut off the power to your indoor unit first as they will still be 240volts available there. If the fuse is blown, replace it and reinstall your thermostat. Turn the power back on. If the thermostat is wired properly with no damaged wires in the process, the system should work fine.
If there is NO fuse, then check the low voltage side of your transformer using a Voltmeter. You will have to have the power on to perform this test. Be very careful. On one side of the transformer, you will read 240volts. The other side should read 24 volts. If there is no voltage on the 24volt side, you blew the transformer and will need to replace it.
Check these items first. If you need further assistance, let us know and we will dig a lil' deeper. :-)
24%20v%20transformer.jpgpicture of a typical transformer.
The low voltage fuse could be a glass cartridge fuse (systems typically older than 15 - 20 years old). Newer systems use the same style fuses that are used in your truck or car (ATC type).
Apr 08, 2010 | Hunter 30124 Air Conditioner
Condenser is buzzing so there is power, but the
The buzzing sound is from the contactor and only means you have low voltage at the unit,Check and make sure you have 240 volts at the unit and post back.
Jun 27, 2009 | Ruud UAMB Air Conditioner
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced...
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Ruud UAMB Air Conditioner Logo
170 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
