Question about Quantaray 50mm f/2.8 AF Tech-10 for Canon EOS
My canon rebel xti got wet and now I am having trouble focusing and then an err99
    Novelist:
  • 164 Answers
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry or the main board, caused for moisture as result of the water that got in.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform some basic diagnostics of the failure. You will need tools to do it, which includes the usage of a soldering iron.
The repair cost may be so huge that is cheaper to buy another camera, since after open it, it may be necessary to replace multiple expensive parts.
Best regards,
Posted on Jul 23, 2009
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
May 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
Aug 25, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
See-through lens is blurry and does not reflect the change in focus when I adjust the wide angle lens on my digital rebel xti. What's the problem and how can I fix it?
Check the AF/MF switch over the lens left side. Should be on AF to let the camera focus by itself. If not, you have to manually focus using the focusing ring.
If the camera is in AF and still no focusing, considere to carry your camera for service.
Aug 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Video
I HAVE A EOS DIGITAL REBEL XTI I WANT TO KNOW IF I CAN USE IT LIKE WET CAM.
PLEASE HELP ME THANK YOU..
Oct 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
Aug 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel xti - auto focus problem
AI should be focusing. You really can't change many settings when you are shooting in auto mode. Is the lens in AF mode?
I'm sure you have long since returned from vacation!
Hope this helps!
Dec 31, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Quantaray 50mm f/2.8 AF Tech-10 for Canon EOS Logo
294 people viewed this question
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
