Question about Lowrance Globalmap 5200c Color Chartplotter
Lowrance 5200c giving "gps module not found" alarm?
Replace antenna module with the 4000 model
Posted on Jul 30, 2009
My global map 5200c curser is blinking a question mark
That question mark means the GPS antenna cannot get a satellite fix for the GPS to triangulate your position.
Be sure there is no aluminum above your antenna. This will block the gps signal. Also be sure your GPS antenna is at least 24" or more away from any other electronics The electromagnetic field electronics emit will disrupt the GPS signal coming to your antenna.
Sep 09, 2014 | Lowrance Globalmap 5200c Color...
Error message
Check the connections pull and replace, also check the base cord of the antenna.
Sep 22, 2009 | Lowrance Globalmap 5200c Color...
Just bought at auction. No manuel.
My apologies. I see now that you have an iWay 250C. Here is the manual as found on the Lowrance website.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iWAY250c-manual_0160-201_080706.pdf
Aug 06, 2009 | Lowrance iWAY 250C GPS Receiver
Can't get out off demo mode - trying to use my chart - navionics gold 20XG but it shows only demo mode. can't find instructions in the manuel or cannot understand them. (part off my problem is that my...
Try this hard reset procedure: (warning: this procedure will erase all waypoints that have been saved)
1. Turn unit off
2. Press and hold the ZIN, ZOUT, and PWR keys at the same time.
3. Release the ZIN, ZOUT, and PWR keys once the alarm "warning, do not rely..." appears.
The unit should now be out of demo mode.
Jul 13, 2009 | Lowrance GlobalMap 5200C GPS Receiver
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
Lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Mar 08, 2009 | Lowrance GlobalMap 3500C GPS Receiver
LOWRANCE 5200c
i need help to mine does the same thing
Nov 08, 2008 | Lowrance Globalmap 5200c Color...
I have a Lowrance LCX 28 c HD I took off old boat and installed on newand when i start it up i get alarm that says GPS Module not responding. What should I check?
the nmea network also needs power.
make sure that the power is connected to the unit and to the network
greeting
g
May 12, 2008 | GPS
Lowrance Globalmap 5200c Color Chartplotter Logo
199 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
