Question about Acer Aspire One PC Notebook
How to repair grub rescue - Acer Aspire One PC Notebook
2 Suggested Answers
SOURCE:
  • 60 Answers
SOURCE: please help!! i can't open my notebook!!! when i
if you need a quick solution see this ubantu forum discussion
http://ubuntuforums.org/showthread.php?t=1357690
or else do a bit of research https://help.ubuntu.com/community/Grub2
Posted on Aug 05, 2011
Upon booting computer, the message:Error:no such partition. Entering rescue mode. Grub rescue.Can you help? Thanks
Your drive most likely failed/corrupted, the computer isn't seeing the original partition you had Windows/your OS installed on. I'd suggest getting a new drive and installing Windows on it, then seeing if you can recover the data off the one that failed from in Windows.
Jan 12, 2018 | The Computers & Internet
Tip
Linux System not Booting: A Troubleshooting Session
<span>In a recent days in our lab I've got a with Linux file system. <span> </span>Our lab used Redhat Linux 5.3 Enterprise version. Redhat Linux is an Unix based Operating System and It based on Ext3 file system</span><br /> <span></span> <br /> <span><span>Problem of Linux:<span> The systen cannot access internet. It shows the license expiry error notification. Some</span></span><span>time it doesn't detect the hard drive. Some time the pc can detect hard drive but the Linux started with some errors of file system. Finally the file system of the OS getting crashed and can't boot. At GRUB loading stage it become restarted.</span></span><br /> <span><span></span></span> <br /> <span><span><span>Solution or Troubleshooting: </span><span>If I replace the hard drive cable It detect well and start OS also. Then the pc can detect hard drive but the Linux started with some errors of file system. Then I discovered that there is a problem with OS.<span> </span>Though formatting can solve the problem but that needs a backup of important data. This is time consuming and risky. So I thought to repair the file system</span>.</span></span><br /> <span><span><span></span></span></span> <br /> <span><span><span>At first I'm trying to login in single user mode and repair the file system. I have tried to login by pressing "s" beside kernel at startup in single user mode. But the system doesn't boot. Then I'm trying to repair the OS by RedHat Linux CD. I <span> </span>Insert the CD and select rescue mode by pressing "F5" key. Then I got the single user mode. After that I check all file system sequentially. </span></span></span><span><span><span>/etc /passwd, /etc/shadow, /etc/securetty, /etc/pam.d/login. Those file was wrong. I updated those file by correcting. Then I update the auth config file. After that I boot the system again. But now also it don't get start. Then I rescue the grub by grub-rescue and also update the kernel. After the total process I'm tried again to login from single user mode in root and It get logged. After that I reboot the system and tried to login. Finally it logged in successfully and run properly.<img src="alokerdas.jpg" /></span></span></span>
on Jan 15, 2011 | Computers & Internet
Have a dual boot system, windows7 & linux. tried to update to windows 10. stuck at grub rescue.
It sounds like grub can't find the correct partition to boot Windows 10. This should get you through it: http://askubuntu.com/questions/654386/windows-10-upgrade-lead-into-grub-rescue
Keep in mind that Microsoft never tested the upgrade on a system that dual boots with Linux and uses the Grub loader. You are in uncharted waters.
Dec 24, 2015 | Computers & Internet
Corrupted os
Have you tried a System Restore/Recovery? Do you have a Recovery Partition? Take a look here: http://www.unixmen.com/fixing-a-few-common-grub-errors-broken-bootloader-and-error-1715/
Apr 29, 2013 | Intel Hasee Nb Q540x-n 13.3" Laptop...
Hello I have a asus 1001p netbook that doesn't
Sounds like a job for a repair shop that can attach an external drive to it and reload the operating system.
May 09, 2012 | ASUS Computers & Internet
Boot loader for fedora8 & windowsxp
Boot a Linux Rescue Disk and Re-Install Grub with the command. "grub-install"
mount /dev/your_boot_partiton /boot
grub-install --root-directory /boot /dev/hda
The Boot Sector is Stored on the first 512 Bytes of the physical Disk.
Sep 23, 2009 | fedora Linux Operating System
GRUB PROBLEM on clone pc with Red hat linux 6.0
Boot up from Installation CD/DVD and type 'linux rescue' at boot: prompt, This will drop you at 'shell' prompt.
execute this
chroot /mnt/sysimage
cd /boot/grub
less grub.conf
less device.map
post the contents of device.map and grub.conf files ( first title, root and kernel lines of grub.conf ).
Apr 03, 2009 | Red Hat Enterprise ES 4 for Linux
Acer Aspire One  PC Notebook Logo
93 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
