Question about Westinghouse LTV-27w6 27 in. LCD HDTV
Repair I have a 27" westinghouse tv that I can not find anyone in the Rochester, NY area to do repair work. The unit will after 20 minutes shut itself off. Do you know of any repair locations in the area or possible solutions to the problem? Thank you
ABC Electronics may help. Look in phone book for #
Posted on Nov 20, 2007
I have a westinghouse ltv-27w2 and after about 15 to 20 minutes it shuts off .i turn it off for about an half hour it comes back on and play for about 15 to 20 minutes again.what is the problem and is it...
Hi my first guess is the power supply. You can inpect it for bulged capacitors that might be obvious. My second thought is the signal board but I leaning more towards the power supply. If you want to buy parts you can find them at in order to get parts you have to get the part numbers from the actual part on your TV. If you open it up it has a part number stamped to it. Be carefull opening up the TV it has high voltage. leave it unplugged for a couple of hours before opening it up.
Jun 02, 2011 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Danby dehumidifier keeps signalling that it is full when the bucket is empty. Have wiped with towels, turned off then on etc. to no avail. can sensors be a problem how do you replace them?Is it something...
The water collection bucket may not be activating the safety trigger, when it's put back in place. Check that first. If that checks out OK, turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Then plug the unit back in and Turn the Master ON/OFF Switch to ON. Hopefully, during that 12-15 minute timeout, the unit reset itself and you set the controls as you normally do.
Yes, the safety trigger sensor can be replaced if parts for that unit are still available. But, sometimes, it's more trouble than it's worth. Especially, if the unit has a few years on it.
Hope this helps you solve the problem. Please let me know.
May 16, 2011 | Danby Dehumidifiers
My Westinghouse TV shuts off when I'm watching after about 15 minutes. Turn off then on and runs maybe 20 minutes then shut off.
This sounds like a power board failure. Try calling your manufacturer and ask them if the TV is still under warranty. If it is have them dispatch a technician to repair the problem. If not, you are better off replacing the TV as the repair cost would exceed it's worth.
Feb 28, 2011 | Westinghouse 32" Flat Panel LCD HDTV
What are my frequencies for the Rochester NY area.
For a comprehensive database of active frequencies in your area, visit:
Jan 01, 2010 | Uniden BC72XLT Handheld Scanner
TV just shuts off on it own... Have a westinghouse LTV-27-W2 TV purchased in 2005. It's been shutting off for no apparent reason... I wonder if it's going bad or is it the power cord.
Most likely, a number of capacitors need to be replaced in the power supply on this set, OR possibly, there is a bad connection on a connection on the snubber capacitor in the power supply, near the SMT transformer--and I have seen this MANY times on westinghouse LCD sets. .
Oct 09, 2009 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Tv shuts itself off
pls check the a.c. cord is good,then check fuse of the unit if deffective need to replace it and check the horizontal output if is good or not.
Jan 11, 2009 | Sanyo DS27510 27" TV
TV shutting off
try this part first 5600110347 you can get it at
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Nov 04, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
81 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
