Question about Emerson EWC1303 13 in. TV/VCR Combo
Where is the remote sensor? - Emerson EWC1303 13 in. TV/VCR Combo
  • 855 Answers
The sensor that you are looking for should be in the ront of the set. It looks like a black or gray dot. Usually located near the button controls on the set. The actual sensor is inside the set behind this, but if you have a clear shot at the dot the sensor does the rest.
Posted on Jun 27, 2009
The remote sensor in the TV unit is not responding
Check the remote control for its infrared emission first. If it found OK, check and replace the remote sensor inside the TV. To get more details, http://electronicshelponline.blogspot.com/ Testing procedure to remote control is given in detail. 5861f1e7-87a3-433c-a8c7-016dc4787f6c.jpgec36d179-61eb-46d0-b8d0-578cf88fc7b0.jpg
Remote sensor will look like this.
Nov 17, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Jvc lt42tg30j remote not working
FACE THE SENSOR OF REMOTE TO THE CAMERA OF YOUR PHONE THEN PRESS ANY NUMBER IN REMOTE IF YOU SEE THAT THE SENSOR LIGHT BLINKS MEANS THE REMOTE IS OK...BUT IF NOT BLINKS I SUGGESTED TO REPLACE THE SENSOR OF THE REMOTE.
Sep 24, 2013 | JVC Televison & Video
Emerson lc320emx remote sensor not working
Some advice--the sensor if bad requires the set to be opened and will be on a tiny board--whole board would have to be replaced as this company does not sell single parts (most now do not).
I would have the remote tested---most shops have a tester where remote is pointed at it---buttons (any or all) pressed to check it.
Some digital cameras when the remote is pointed at them will have a flash when the remote is used---
Either the remote or the sensor or something near the sensor is the problem.
If remote held very close to sensor and works----sensor is the problem most of the time.
Apr 16, 2012 | Emerson LC320EMX 32 in. LCD HDTV
T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Nov 28, 2011 | Televison & Video
Sensor for remote is not working on the tv
Tries a little Alcahol with a Q tip clean the tv IR sensor,do the same to the remote and change batteries,tv sensor saldom broken,only remote all the time.Tries this Website 1-800-Remotes Factory Original for new remote get the exact or very close to the original.
Sep 30, 2009 | Televison & Video
Remote sensor on TV (LG 42PM1MA) seems to be broken. All of a sudden the remote stopped working. So I replaced the batteries. Still not working. So I figured the remote must have given up. So I went out to...
Have the technician check for 5 volts on the remote IR Sensor if present the the Remote sensor has failed. Have him replace it to factory Spec's. No need to replace entire main board when the sensor is no more 5 dollars....
Sep 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Hi i have a eurovox max.i can turn the channels over on the box but not with the remote.i have tried 3 remotes with it but it still doesnt work.is it my remote or the box.
If you have tried 3 remotes most likely the problem will be with the remote sensor on the box. There is a common problem with the solder joints for the remote sensor u can test your remote sensor and box sensor with your phone camera if you press a button on the remote and move the camera over it u will see it lights up if it doesnt then remote sensor or box sensor not working. Repeat process for box sensor with camera. Sometimes you can just re-solder the sensor and it will work if not you will need another sensor. Good Luck.
Apr 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Emerson EWC1303 13 in. TV/VCR Combo Logo
183 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
