Question about Refrigerators
Kenmore side-by-side refridgerator. Freezer door was left ajar overnight. Apparently ice melted onto the dispenser motor are and refroze. Motor activates (makes sounds) but cannot turn. How do I disassemble the dispenser to remove the motor to thaw and dry it, or even to replace it?
  • 4 more comments
  • larry65 Jun 27, 2009
    Thank you for the suggestion. The HowStuffWorks link was interesting but very generic, and offered no clues about accessing a Kenmore dispenser motor.
    I am still hoping someone can tell me how to access the motor inside the ice/water dispenser. It appears fromhttp://www.applianceaid.com/ken_whirl_di... that the dispenser itself comes off from the front. Is the motor then accessible?
    It's a Kenmore (Whirlpool) 106.5156410.
    The ice bin had gotten warm enough to let meltwater get everywhere. I'm hoping that the noise I hear is the motor wanting to turn. I considered emptying the unit and letting everything thaw, but am hoping that I might be able to get just the motor out and get it thawed and dry.
    It feels like I can pull off the plastic facings on the exterior of the door, but I don't want to accidentally break any clips, tangs, snaps...
  • larry65 Jun 28, 2009
    Thanks for the detailed reply. However, the actual icemaker is making ice.
    My problem is the in-door dispenser. I can only get ice out of the bin by opening the door and grabbing cubes. Neither cubes nor crushed will dispense. The motor makes humming sounds but does not turn. Even if the bin is removed, I hear the motor trying to turn, but nothing turns.
    How do I get to the *dispenser* motor?
    Thanks!
  • larry65 Jul 06, 2009
    Not a problem with the actual icemaker. It fills the storage bin. I just can't get any ice out through the dispenser. When the freezer door was left ajar, melted ice got into the motor drive beneath the ice storage bin. It is now frozen and needs to be removed.
    How do I take off the dispenser on the outer (room) side of the freezer door to access the dispenser motor?
    Thanks!
    Thanks for your assistance! I had already tried most of the applicable suggestions, but the link you provided to the service manual had the additional information I was looking for.
    President:
  • 1,952 Answers
For a refrigerator to provide ice through the door, the ice maker first dumps the ice it produces into a large bin. To request ice at the door, a person presses a lever that activates a switch. The switch turns on a motor that rotates the auger. When the auger rotates, it pushes ice out of the bin, through a chute to the user.
The water dispenser works much like the ice dispenser. To request water at the door, a person presses a lever on the front of the refrigerator that activates a switch. The switch turns on an electric water valve at the back of the refrigerator. Water flows through the valve into a tube, then flows into a container in the refrigerator to be chilled. As new water enters the container, the water that is displaced flows through a separate tube to the user.
Posted on Jul 06, 2009
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Jul 06, 2009
    • The ice
      maker sends a signal to the water fill valve (normally located on the
      outside back of the refrigerator, near the bottom) to open and let
      water into the ice maker tray. The amount of water is determined by a
      cam and switch within the ice maker control panel. The icemaker sends
      the signal to open the water valve for a certain length of time (7-10
      seconds)then stops the signal.
    • The ice maker waits
      until the water is frozen--which it senses with a small thermostat
      located near the water tray. When the tray reaches approximately 10-15
      degrees Fahrenheit , the ice maker begins to harvest (eject) the cubes.
    • To harvest the cubes, the ice maker first turns on a
      small heater beneath the tray. The heater warms the tray slightly,
      which allows the ice cubes to move freely.
    • Then a sweep fork rotates and pushes the cubes up and out of the tray.
    • While
      the ice maker is dumping the cubes into a holding bin, a metal wire
      similar to a coat hanger swings up to let the cubes drop below it. When
      the cubes have dropped, the wire comes back down. If the holding bin is
      full of ice, the wire cannot come all the way back down, which stops
      further production of ice.
    • When the wire is allowed to come back down all the way, the ice maker refills with water and repeats the process.
    Factory Service Manual try this site
    If the three mounting screws are taken off there is just enough
    freeplay in the motor and the housing to attach the boot without
    removing the nut holding the U shaped blade in place.
    Looks like the small sheet metal cover around the motor needs to be removed in order to fit the boot in place.
    Hope this helps others with a similar issue.
    Remove the ice container and try the dispenser to listen for the motor.
    If you hear it turning, empty the ice container and try turning it by
    hand.
    If the motor still doesn't run try turning the motor shaft.
    You may have to use some pliers to turn it if is frozen. Once you are
    able to turn it by hand, try the dispenser again.
    President:
  • 828 Answers
Defrooze first and find out some manuals in the web to remove the freezer..
Posted on Jun 28, 2009
  • 15,935 Answers
There should not be a problem with the ice getting to the motor - the auger motor is well above any water level.
Please use the "Continue with This Expert" option and reply with your exact make & model # so I can assist you better and provide the information you need to get your ice maker up and running again.
Thanks :D
Posted on Jun 27, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jun 27, 2009
    CLICK HERE to see the ACTUAL expanded view of your icemaker.
    The motor is #37 on the diagram and available for order HERE
    You are correct - remove the plastic trim cover - and the motor is mounted to the back of the timer assembly.
    However - it would be best to remove the icemaker and get it dried out and re-try - as it may just be unable to move because of the ice buildup.
    It should mount with 4 screws (sometimes 2) to the wall of the fridge.
    All you will need to do is turn off the water supply... disconnect the power plug, and water line inside the freezer - then let it thaw on the counter.
    Before re-mounting it - plug it back in and see if the ejector arms move as they should.
    While its out - you can also check the heater for proper resistance. (requires a digital multimeter)
    If you need further assistance - let me know by using the "Continue with This Expert" option again.
    Please be sure to rate this answer as FixYa so credit is distributed properly.
  • blueextc3221
    btw - the icemaker is accessed on the inside of the freezer... not through the door.
  • blueextc3221
    blueextc3221 Jul 02, 2009
    Thanks for using FixYa!!
    This is an attempt to follow up on a question you submitted that remains open on our open work queue.
    Experts on FixYa work hard in an attempt to troubleshoot problems remotely.
    Returning to your account and rating or changing My (or the person's that helped the most) answer is appreciated...
    As after 7 days, the fee you paid is credited to the very first Expert to reply - even if it was not related to your problem or helpful to you.
    If you need additional help - please use the "Continue with this Expert" option so we are connected in the future.
    In any case - please rate as FixYa to remove your question from the Work Queue.
    Thanks for using FixYA!!
  • 3,230 Answers
Follow the below link for step by step info.(with images) -
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Good Luck!!
Thanks
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our power went out a week ago and since then our Kitchenaid side by side will not despense ice from the door,it makes ice but will not dispense. We cleaned it our thinking ice had melted and then refroze...
The auger motor is frozen. Open the freezer door and remove the 4 screw holding the auger motor. Unplug the harness. Put it on the counter and use a blow dryer to defrost it. Shake out the water thats inside. Do this until u think all the water is out, then put it back in door and plug it in. You should be good from then on. If you loose power again. Remember to remove ice bucket or water will leak into motor again.
Jul 17, 2011 | Refrigerators
Have a frost free freezer kids left door ajar all
You should unplugged and let all the ice melt and help it with a hair dryer.
Oct 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
Aug 28, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
I have a Kenmore Elite side by side refrigerator/freezer and just had the ice dispenser motor replaced a month ago when we first moved in our new house. However, our daughter left the freezer door ajar...
It would not hurt the motor as they are built to be exposed to some degree of moisture if the defrost does not work i would check and see if something is jamming the actual mech. up. In my ice dispenser i had stuff fall in from the shelf's and seized up the motor. Any how if the thaw does not work check out a motor at repairclinic.com (http://www.repairclinic.com/SSPartDetail.aspx?s=t-106.53769202-%3d%3dc203i1057785&PartID=1057785)
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool refrigerator ice despenser
To All With This Same Problem ,
Remove the top freezer door hinge cover ( 1 screw holding it on ) , and disconnect the plug there . This will disconnect the power to the door dispensor .
Using a butter knife or small screwdriver , insert it in the bottom of the dispensor cover between the grill and the cover .
Push down and in wards , to force the bottom of the cover outward , being careful not to break the 2 or 3 built on plastic clips on the cover .
After the lower portion has been disconnected , lift the cover up to disconnect the top clips and then remove the plug on the cover .
The white piece on the dispensor now visible , is the bracket control .
The switch on the right side , is for water , the switch on the left side , is for ice . Usually , the ice switch , has a broken " spear " , which holds the switch in place . The whole bracket control , pt # 2180226 , will have to be replaced . Only 2 or 4 screws hold it on .
This part is easily replaceable by the consumer .
Just be careful when installing the switch , not to break the new " spears " and be sure to reinstall the plastic " spacers " in the same spot on the new bracket .
When reinstalling the dispensor cover , slip the top on first , and just lightly " pop " the bottom back in place .
Jun 19, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
