I have tried and tried to raise the bobbin thread, but it seems like the sewing thread gets caught somewhere and it just won't raise the bobbin thread.
Make sure that your needle is ALL THE WAY up in the needle clamp and the flat side of the needle is away from you.towards the back.
Review the steps for inserting a bobbin in the bobbin case and raising the thread in your user's manual; if you don't have it, you can download it free at the Singer Sewing Machine site.
If you have done these things and you still can't get the thread to come up, then your timing has gone out of synchronization, and you will need to get a technician to reset it for you. If you cannot find a sewing machine technician willing to adjust a Singer, Sears supports all brands of sewing machine.
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
SOURCE: Touch & Sew zig-zag model 758 - bobbin thread
email me for retiming instructions and remind me of your make, [email protected]
