Question about Kenmore 73952 Gas Dryer
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
  • 126 Answers
Replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Posted on Jun 27, 2009
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Kenmore series 80 gas dryer 6 yrs old will start and tumble but will not heat up
Gas dryers have an ignition panel that gets hot and when it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Kenmore Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore Dryer not drying
First you will need to chekc the exuagst venting and that noone has pushed the dryer too far back kinking the vent. If its not heating whatsoever You may need to check the internal fuses which may be located using the mini manual located in the dryer control panel.
Mar 29, 2009 | Dryers
Kenmore 80 series dryer won't start
Look for a bad thermal fus0526080941.jpge pix below.Straight wire to test it.Replace if the dryer turns on. 2nd. Test the door switch.
Please rate This !
Jul 09, 2008 | Kenmore 63942 Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
May 08, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
501 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
