Did you charge the battery correct? Was the power light on the camera blinking while charging? Did it take about or less than 3 and a half hour tho charge? Please also check if all contacts o the battery and in the camera are clean and shiny. To clean the contacts, only use dry cloth and / or cotton swabs. Also make sure the battery-chamber/ memory card slot cover is closed correct. There is a switch detecting an open door. As long as the door is open the camera won't start.
IGNITION SWITCH REPLACING
It
depends on vehicle to vehicle. But it's not very difficult on mot of cars to
replace ignition switch. Basic theory of replacing ignition switch is same for
all car models. -----
To
replace ignition switch on your vehicle, I suggest you
few helplinks with proper ignition switch replacing procedure.
View its details and you can replace ignition switch on your
vehicle.
Click
the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on
Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
