Question about HP Compaq Presario SR2150NX PC Desktop
Noices my computer is making noices when i open it one of the fans is moving slow i touch it and it moves faster and the noice stops
  • 2,961 Answers
Re: noices
There are two fans the heatsink fan and an extractor fan, either of theses can be replaced, you buy the heatsink and fan together for the processor and a seperate case fan can be fitted easily by yourself
Posted on Nov 06, 2007
0 characters
3 Points
Wont boot and clicking noice
A clicking noise usually indicates a bad hard drive. Any eMachine is now very old (in computer years), with an obsolete operating system.
You should consider replacing rather than repairing.
Jan 09, 2013 | E-Machines eMachines Desktop PC
How to upplug fan in desktop
How to Reduce the Noise of Your CPU Fan
The CPU fan is what keeps the processor of your computer cool while the machine is running. A noisy fan on the CPU can be very annoying for users of the computer. However, it can also be a sign of a dangerous problem in your system. If the CPU fan is making noise, it is probably not running at full capacity to cool the processor, which leaves your computer open to problems involving overheating of the processor. An overheated processor can be permanently damaged.
Step 1
Unplug the computer from the wall. Remove all devices from the back of the computer and move them away from the area where you will be working. Either wear an anti-static wristband or discharge any static by touching a metal part of the computer case.
Step 2
Remove the screws from the back of the computer case with a screwdriver. Pull the sides of the case off and set them aside. Lay the computer on its side so that you can easily see the motherboard and all parts connected to it. Locate the CPU fan; it will look similar to the image in the introduction.
Step 3
Ensure that no cables are hanging low and touching the blades of the CPU fan. Move any cables or other parts that could be hitting the blades of the fan causing noise. Tuck these cables and wires into an area where they cannot interfere with the CPU fan.
Step 4
Use a cotton swab to remove any dust that you can from the blades of the CPU fan. Don't use any harsh solvents or other cleaners that could drip down and damage the processor through the fan.
Step 5
Spray the compressed air into the fan to move the loose dust away from the processor fan. Move the dust into an empty section of the case with the canned air. Don't spray the air too hard or else you can spread the dust into other places in the computer.
Step 6
Use the vacuum cleaner to vacuum up the dust that you moved away from the CPU. Place a crevice tool or other attachment onto the hose to reduce the size of the opening and help ensure that you only remove dust.
Step 7
Replace the computer case. Plug the computer and all devices back in. Boot up the computer and check for reduced CPU fan noise.
Oct 31, 2012 | HP PC Desktops
Why is my computer shutting down suddenly
A computer that turns off without warning is often a heat related issue. Many computers today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets too hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing, this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer, you will need to either open the computer and make sure the fan are working and if your BIOS monitors the RPM of the fans, enter BIOS and make sure the BIOS does not report any errors.
If you need any kind of technical assistance, you can contact support cell at
Sep 14, 2012 | Compaq Evo D500 PC Desktop
de frag it. go into your start menu/accesories/system tools/ disk defragmenter. it will take a few hours but it will make you computer run faster. basically it takes all the files that are spread out and compresses them to create more space and make it run faster
Sep 13, 2010 | PC Desktops
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
My pc is moveing slow can it move faster
You can make a computer move faster by removing some unecessary program that is installed on your computer to free up some memroy space and the best way to make much faster is upgrading the RAM or memory of the computer because the higher the RAM/memory the faster the computer works..
Hope that helps.......
Sep 06, 2008 | PC Desktops
Freeeeeeeze problem
Sounds like you may have a bad power supply. It's a cheap fix, abd always a good upgrade. I recommend at least a 400 watt power supply.
Mar 19, 2008 | Sony VAIO PCV-W600G PC Desktop
CPU Fan.
Make Sure your thermal compound is properly placed, check the temp of your CPU. CPU might be overheating due to destroyed layer of compound and therefore Fans run faster...
Sep 27, 2006 | Gateway 500GR PC Desktop
HP Compaq Presario SR2150NX PC Desktop Logo
89 people viewed this question
Top HP PC Desktops Experts
Fred Sops
john smith
 Mike M
Mike M
Are you a HP PC Desktop Expert? Answer questions, earn points and help others
