Question about AOpen AX3S (91.87A10.001) Motherboard
AOpen AX3S I upgraded the BIOS and after that my RAM (256 mb) is not compatible with the PC, i think so cause the system is down and when you try to reinstall de system appear an error named 7 and its information. If i put a 128 mb RAM the system run normally. May the upgraded cause these problems?
  • 661 Answers
It may be possible that the memory that you are trying to use may not be completly compatible with the architecture of the motherboard, if you are using Win XP SP2 you will need a minimum of 512 Mb mem otherwise it will run slowly (especially if running norton AV or Mcafee AV)
It would be a good Idea to buy replacement memory, as the compatibility of the memory you are trying to use is in question.
Kingston memory have a "configurator" which ensures that you get the correct memory for their board, and their memory has a lifetime warranty.
Posted on Nov 18, 2007
I wanted to extend the RAM of a Laptop Toshiba Satellite S1400-503 (approx. 10 years old) from 256 MB to 2*512 MB (PC133) but the system doesn't start. Only various beeps with dark screen occur. I read...
You have the last bios they made for that machine. If the original memory will still boot the machine, one or both of the memory modules you are using are not compatible, defective or not seated correctly. If not you have some other problem. Not all PC 133 chips are created equal. Check the manual if you need to; . You can try replacing the original chjp in slot A and one of the new chips in slot B sometimes that works but you may have stability issues if the new chip is not 100% compatible.
Oct 09, 2013 | Computers & Internet
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
My pc was working fine with 128 + 256 ram. few days ago it didnt was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards) u decide...
pls revert back...and kindly leave a feedback and rating for this will help me move to Guru" here from Expert at Fixya....
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Well i have a compaq presario 1700 XL360 it came with pc100 64 memory ram i tried to upgraded with two 256 memory ram to bring it to total 512 mb thats the max for this computer ...
There is a good chance that your system needs a firmware upgrade in order to recognize the bigger memory. I found one in this page
Be carefull and follow the instructions since you could brick your system.
If that does not work, do not expend more money in that system (very old), just save to get a new one.
P.S. The memory you got is the right kind.
Good luck
Dec 12, 2008 | Compaq Presario 1700 Notebook
Upgrade ram on 12XL125
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory
This system will not be able to use the ram you are trying to install.  For more about this system go to this link:
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
Unable to install Windows xp
If you can afford it i'd look at trying another stick of 256 or a new 512 stick, XP doesn't really like anything under 512 and it pretty much won't run at all with 128, so if you can get it cheaply try that first if that doesn't fix it let me know
Oct 30, 2007 | AOpen MK77M-II Motherboard
AOpen AX3S (91.87A10.001) Motherboard Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
