Question about Creative Labs Creative Webcam
Each time y disconect the webcam and connect it the image becomes dizzy
    President:
  • 8,637 Answers
After you install the webcam drivers and it is working properly, DO NOT unplug the camera as it will cause the drivers to become corrupt and render the camera unusable. Then you have to reinstall the software drivers to correct the problem.
Do this to get it operational:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Aug 14, 2009
  • 2 more comments
  • Weldon Dube'
    Weldon Dube' Aug 28, 2009
    Once you properly install your webcam software, DO NOT disconnect the USB port as it will cause the drivers to be corrupt and render the camera unuable till reinstalled.
    Follow the instructions below and it will work.
    A. Skype Setup:
    After downloading and installing Skype http://www.skype.com/intl/en-gb/download... set it up as follows:
    B. Yahoo Setup:
    After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.html ) set it up as follows:
    Microphone
    Speaker
    Camera
    Notes:
    After you get your camera installed properly, DO NOT unplug it from the USB port as it will cause
    the drivers to be corrupt and render the camera unusable till reinstalled it properly.
  • Weldon Dube'
    Weldon Dube' Aug 31, 2009
    After you have successfully installed the camera software, DO NOT unplug the USB port as it will cause the camera drivers to become corrupt and render the camera unusable till reinstalled properly.
    A. Skype Setup:
    B. Yahoo Setup:
    Microphone
    Speaker
    Camera
    Notes:
  • Weldon Dube'
    Weldon Dube' Nov 21, 2009
    Once you have properly install the software drivers for camera, DO NOT UNPLUG it from the USB port unless you have powered down your laptop computer as it
    will cause the drivers to become corrupt. Like wise plug in the camera into the USB port before powering up your desktop computer or your laptop so the computer
    will recognize the camera and drivers that are installed.
    properly.
    A. Skype Setup:
    see and her to you.
    B. Yahoo Setup:
    Microphone
    Speaker
    Camera
    Notes:
    cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
  • Weldon Dube'
    Weldon Dube' Nov 23, 2009
    Just plugging the Camera into the USB port does not set the camera up to use. It requires that the CD or downloaded software for the camera
    (software drivers) be installed properly.
    Once you have properly install the software drivers for camera, DO NOT UNPLUG it from the USB port unless you have powered down your laptop computer or Desktop Computer as it will cause the Camera drivers to become corrupt. Like wise plug the camera into the USB port before powering up your laptop or the desktop computer so it will recognize the camera and drivers that are installed.
    Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up
    A. Skype Setup:
    After downloading and installing Skype http://www.skype.com/intl/en-gb/download... )
    The camera, if Installed Properly, it will come up and show a video picture.
    Then, on the bottom of the page click save.
    The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
    B. Yahoo Setup:
    After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.HTML )
    Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the
    left window.
    http://www.microsoft.com/downloads/detai...
    Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
    Next go to the Menu Bar on right side, click on " "Action."
    Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
    D. AIM (AOL) Messenger:
    http://dashboard.aim.com/aim
    On the VIM sign-in window, click on Edit.
    Microphone
    Speaker
    Camera
    The audio and camera should function now.
    Additional information to use with VIM settings.
    Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
    Properly. Follow the on-screen prompts.
    Notes:
    Yes button.
    at the
    Picture-in-picture (PIP) display.
Wires under the dash not connected no heater,blower,window don't work ect.
My first qiestion is were the accesories working prior to these wires becoming disconected? If so is it a connector that is disconected or just wires hanging under your dash?
Oct 13, 2013 | Cars & Trucks
Want that my panasonic dmc-lz7 become a webcam but it cannot connect to my pc
The camera is designed to store images and videos onto a memory card, not to stream them live to a computer. It cannot be used as a webcam.
Feb 06, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
No clear picture of partner by using Skype
Please uninstall and re-install your skype once more, ths would solve the problem.
Regards
Oct 19, 2009 | Logitech Webcam
The webcam image is not clear when it is in full screen mode
its a low resolution image, the larger the image is made, the larger the pixels become and this makes the image blurry. unfortunately nothing can be done about this besides buying a higher resolution camera.
Jun 18, 2009 | Computers & Internet
Frozen picture
from what you describe the issue is from the other persons computer.
Aug 31, 2008 | Creative Labs WebCam Live!
Fuzzy image
if you are in a poorly lit room, the picture becomes fuzzy, or you need to reinstall your graphics driver to give a better image clarity
Aug 17, 2008 | Creative Labs WebCam Live!
Webcam
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Feb 28, 2008 | Logitech Webcam
My webcam has all of the sudden started running slow on msn, it didn't before, so I don't understand why it is now, I've installed 3 different cams and it's doing the same with each one
Feb 27, 2008 | Logitech Webcam
Webcam freeze, bad cam or what?
It is not the web cam or the computer why it freezes. It is the internet connection using in the philippines. the upload stream is too slow thats it lags the image. It could also be caused by the computer memory. But most of the time it is the connection. Be sure that when he/ she is using the webcam, shes not doing other things on the internet like downloading or browsing.
Feb 11, 2008 | Logitech Webcam
Blurry Webcam
okay this is what u all do XD
u kno the white part around the camera, like by the lens...
turn that counterclockwise, at first it wont move.. but eventually it will u just gotta try
well anyways hope that helps u guys out :]
Jan 22, 2008 | Logitech Webcam
Creative Labs Creative Webcam Logo
21 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
