Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My tv will not stay on
My rca tv will turn on then turn off 3 times in a row then i have to wait 60 seconds before i can try it again. it will not stay on
  • 261 Answers
Hi Kim8876 It seems to be the ballast from your tv which doesn't have enough voltage on it to keep up with your lamp, i know this guys at discountdashmerchantdotcom check the, out the tech support is great, they'll be able to help you a lot :)
Good Luck!
Posted on Jun 29, 2009
    Genius:
  • 1,139 Answers
Hello kim8876,
I posted this solution earlier, but it applies here too.
The problem happens to be a series of capacitors. your TV uses the ITC222 Thomson chassis and it has a flaw in which CP150, CP140, and CP120 dries out and then explodes or becomes bloated and causes the problem you are reporting. Here is a URL to get the schematic daiagram:
http://www.eserviceinfo.com/downloadsm/3692/Thomson_ITC222.html
Once you have the schematic, the actual component is on the Deflection board (the one on your right hand side facing the back of the set. The component is behind a heat sink with a transistor on it. Now make sure you find all three capacitors (the two other are on the same deflection board).
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 27, 2009
How do i program my rca remote to my 42 inch samsaung tv
you can try a code search
  1. Turn on the tv you want to program.
  2. Press and hold both the button for the component along with the power button until the light comes on and stays on.
  3. Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
  4. Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on. You may have to do this up to 10 times until it searches through the bank of ten codes sent.
  5. Press and hold the stop button until the light goes off. This saves the code.
Mar 03, 2011 | RCA 3-Device Universal Remote
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
RCA tv will not stay on
Sounds like the flyback very famous for that model. You need Flyback 270125 you can get the new RCA flyback at the following link and they provide step by step detailed indtructions on how to do the repair. Heres the link to your flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/270125/cName/flybacks
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
Power won't stay on
did you ever get this fixed mine does the same thing,replaced the caps in the power supply but still won't work
Apr 06, 2009 | RCA Televison & Video
Rca tv d52w14
replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
Jan 17, 2009 | Televison & Video
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
