Question about Toshiba Tecra 9000 Notebook
My toggle mouse on my Toshiba Techra only works left-to-right
Toggle will not go up or down; only left and right. Can anyone help?
  • jimdonithan Jun 29, 2009
    Gee, every one of these links seem to take me to the same site,
    http://www.esmadrid.com/en/portal.do&...">Weekend in Madrid
    Get to know Madrid in your holiday! All the information in esmadrid.com
    www.esmadrid.com
    Since I'm more interested in fixing my laptop, I'll have to pass on this "great" advice.
  • jimdonithan Jul 13, 2009
    Wow... even more useless sites to sell me something! I am impressed.
The up and down scroll of the touchpad on my acer aspire 5630 with windows vista is not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 29, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Set touch pad to function
May 24, 2012 | Toshiba Computers & Internet
Touch pad set up
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
How do I unlock
Are you into Windows and see your desktop icon when this happens?
If so you might have your touchpad toggled off.
May 15, 2012 | Toshiba Computers & Internet
Toshiba satellite l505 mouse/click pad stopped working. Does not respond always. Either gets
Maybe you pressed the button to lock the touchpad. On some models there is a button located at the top of the touchpad in the middle that toggles the touchpad/mouse on or off.
On other models you have to tap twice in the upper left hand corner of the touchpad to toggle it on or off.
Some models you have to Press and Hold the ALT or FN key then hit the key that toggles the touchpad. Normally the key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touch pad.
If all fails you can always download and reinstall the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 26, 2012 | Toshiba Computers & Internet
I need a user manual for my badger,dynacraft mkii bait boat
not much to it really .Left toggle forward for speed (get used to running boat slow before you drop bait,takes a bit of practise).Left toggle back opens hopper to drop bait and rig.(Adjust trimmer nearby so motor not running when toggle not operated, usually about 3/4 up) Right toggle for direction left/right (adjust trimmer nearby if boat sails left or right) Get used to just a quick flick of the toggle to direct the boat. Leave handset aerial one section short of fully up in case you sail out of range.Hope this helps
Jan 26, 2011 | Sport & Outdoor - Others
I cant use my mouse pad anymore...what keys did my cat presswhen she walked on it...so i can unlock the mouse pad again
Try pressing the Fn button (between Ctrl & Alt) and while holding it down press F9 to toggle the mouse off /on. Hope it helps.
Oct 11, 2010 | Toshiba Satellite A105 Notebook
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
When typing on toshiba the curser skip and actually moves
It might be that your palm is brushing across the intel touch pad (mouse pad) as you're typing?.. try holding down the function key (Fn) (on the lower left corner of the keyboard) while pressing F9 (this activates the "Toshiba Flash Cards Menu" and is a keyboard shortcut to toggle off/on the touch/mouse pad. You can turn it back on this way too. I almost always use a conventional USB mouse with my laptop for this reason and because it's faster than fiddling around with the pad, IMHO).
Dec 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
Language
I was having the same problem. If you have the same digital mp3 player, like I have, this it what I did. It's kind of tough to explain, but I'll give it a shot. After you turn on your player, hold down your toggle switch on top of your player until you get to a 5th showing. Such as 1/5, 2/5, 3/5, etc. Once you get that in your screen, move your toggle switch either left or right until you get to 4/5, that's your settings. Once there press your toggle switch down once. From there it should show the 8ths. Such as 1/8, 2/8, 3/8, etc. Move your toggle switch left or right until you get to 3/8, that's your language settings. Press your toggle switch down once and move it until your find 2/9, that's the english setting. Press toggle down once and it should be set. I hope I was able to help you.
Oct 22, 2007 | Sonic Impact Technologies 5070 256 MB MP3...
Toshiba Tecra 9000 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
