Question about Rowenta DX6700 Iron
Brown water staining clothes when ironing - Rowenta DX6700 Iron
    Sergeant:
  • 353 Answers
Either the water has sat in the iron too long between uses
or its the iron in the water you use.
you will have to flush out the old water.
try distilled water
Posted on Jun 27, 2009
Distilled Water is not recommended for use in Rowenta irons. It may cause dripping from the iron. If you have hard water, you may have to use the self clean function on the iron more often.
Posted on Oct 23, 2009
5 Suggested Answers
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
fathitkf
  • 1871 Answers
SOURCE: It leaks water when I iron
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Posted on Apr 18, 2010
SOURCE: BRown water and stuff coming out of iron
To clean the sole plate, Rowenta has a sole plate cleaning kit for $9.99, however, Dritz sewing notions makes one too and it is much cheaper. You take an old CLEAN dishcloth and squeeze about an inch of the cleaner on the towel. Using a hot, dry iron move it back and forth over the cleaner until the sole plate is smooth and clean. I then use a q-tip to clean any residue from the sole plate. Keep turning the towel until all the cleaner is removed from the iron. Any time my iron becomes sticky I use this method and it works great.
Posted on May 06, 2008
  • 46 Answers
SOURCE: Dripping brown-spotted water on clothes while ironing.
Your water could have high iron content, therefore empty out the old water and use Distilled water in the iron.
If you are using Distilled water already then it's a problem with the inside of the iron. Get a new iron.
Posted on May 23, 2009
I have had this iron (Norelco Ultima 50) for 20+ years and it is starting to periodically spurt out lite brown and staining my clothes. I love this iron and dont want to give it up....help!
Light brown sounds like rust. I would get some "CLR", and run that through the iron. Rinse out with clear water several times, so you get all the stuff out.
Jul 15, 2015 | Irons
How do I descale my iron
To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the lime scale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any residual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Oct 29, 2013 | Irons
We have a GC8420 steam iron. The steam is regularly discoloured, first a pink, chalky stain - very difficult to get out of fabrics - and today a lot of dark brown/black water coming out. We do empty out...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Jul 14, 2011 | Philips Irons
Rust colored steam that stains clothing ironed
heatman101
Mar 22, 2011 | Rowenta DZ1700 Iron
I use distilled water in my Roweta. When ironing a white shirt this morning, brown water came out and stained the shirt. What could have caused this and what can I do in the future to avoid this?
Brown water and white scale are often the result of the water you use in the iron...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Jan 22, 2011 | Rowenta DX6700 Iron
I get lots of brown stained clothes when i use my tefal steam generator iron have tried to de-scale it using the hose and then using 1 part vinegar to 3 parts water and it still keeps happening anyone...
Ok. sounds like you have lots of iron( Fe) in your water. You must always use only distilled water in the unit or you will get stains and eventual failure of the unit. The other possibility is contamination of the ironing surface or ironing spray product. 250 Pounds is the most expensive iron I have ever heard of outside of a commercial model,so it would certainly be worth taking to a shop for checking if nothing else works. I wish you good fortune, farmerbear at FixYa.com
Sep 29, 2010 | Tefal Irons
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Rowenta DX6700 Iron Logo
929 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
