Question about Boating
We have very little reverse any thing above idle the prop just seams to slip 76 johnson 85 hp outboard thanks Ben
  • 5,687 Answers
There are two things to look for. With the motor off disconnect the shift cable. Pull the boots off the plugs so the engine can't kick back. Grab the shift lever directly on the motor and pull it in the direction reverse is. Turn the prop and you should be able to feel reverse click in. If you just barely feel it "tick" the gears, the shift rod inside the housing is not adjusted. If the reverse "bites" into place as good as forward then leave it is that position. Next, line up the shift cable but DO NOT connect the end with the shift lever. Put the cable in reverse and you will see a gap from the old setting to the where it has to be to work correctly. Then its as simply as adjusting the shift cable to match the lever.
The second possibility is the rubber hub in the prop. It could be slipping. But usually its gone in both directions when this part breaks.
Posted on Jun 27, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Check the adjustment on the gear cable as it sounds like not selecting fully ! or the clutch selector or the gear could be worn , which you can have recut by a machine shop saving you buying a set of gears !!
Posted on May 30, 2014
    Problem Solver:
  • 5 Answers
It is a hydro shift ..therefor you will not find reverse by turning the prop at all!!!!!! The engine has to run to build fluid pressure to shift into reverse ,like a car automatic transmission.
Posted on Jul 27, 2009
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
Put outboard in gear and prop turns ,anything abohe idle prop doesnt keep up 30hp
with engine off put in gear and check prop fully in gear , get a friend to hold the flywheel solid and you put pressure on the prop and if you can turn it try adjusting linkage to get more selection in forward then check neuteral and reverse ok also ! check the prop bush isnt slipping also !
Sep 03, 2014 | Motorcycles
Johnson trim tilt problems
WWW.OVERTONS.COM ORDER A SELOC SHOP MANUAL
Jul 23, 2013 | Boating
1985 johnson 85 hp outboard troubleshooting
You can use auto scanner to check the engine system. Make sure i don't fault codes.
Jul 23, 2013 | Cars & Trucks
I have an 85 HP Mercury Outboard and when you get to about 4000 rpm's it sounds like it is slipping, what can I look for..........
In the propeller is a rubber hub.It's between the driveshaft and the prop.Its job is to stop major damage if you hit something causing driveline damage.It will be starting to slip.Its called the rubber bush.It will need to be looked at.Take it to a prop shop because if you take it to a dealer,they will take it to a prop shop.More cost.Hope this helps
Jun 02, 2010 | Boating
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
I have a 1970's 25hp Johnson outboard motor. Last
Hello Adam.
If your propeller is OK, your lower unit will need some repair. It may be as simple as a clutch dog worn and not engaging the gear. Usually they give warnings of problems by jumping out of gear though.
Other possibilities are broken driveshaft, propshaft, or gears. If it goes into reverse the shafts are OK and the clutch and forward gear become suspect.
It was common for these engines to break at the top of the driveshaft where they were tapered.This would give you no motion at all and no previous warning of a problem.
Check the gear lube for metal particles and signs of water intrusion. I hope your repair is an easy one.
KL
Dec 08, 2009 | Boating
Outboard boat engine shifting problems
Check for a lose or sloppy shift linkage.
Mar 30, 2009 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Boating Logo
205 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
