Question about Briggs & Stratton Garden
I was cutting grass with My Riding Lawn Moore I herd a loud noise and it shut down. When I crank it it spins but no contact or fire. Crank and blades turn but no sounds of starting. It is spinning like a car when the timming belt breaks.
  • 4speaks Jun 27, 2009
    Thanks for the info. Can you tell me where the shaft key is located on the Murray Select Mower.
    Scholar:
  • 190 Answers
Check fuel pump and check gas tank and filter for dirt, check oil level if all ok check kill switches also it maybe the shaft key may have broke it is just a long square piece of metal that is hammered in to a grove in the shaft and is meant to brake off so the shaft wont break if something hard is hit. The mower wont start till this is replaced.
Posted on Jun 27, 2009
My z5426 has allways left grass behind,i have to cut my lawn twice
Are your blades sharp? Are they lined up so they do not leave grass in between them as they spin?
Is your cutting deck level or is one side higher than the other.
These are all things that could cause long grass to remain.
Some times a bent blade will do this also.
I even had a lawn mower come in and the blades were installed up side down. He wondered why it would not cut right.
Aug 20, 2016 | Husqvarna Zero Turn Mower Z5426
My craftsman ys4500 21hp riding lawn mower cranks but won't fire and I have tried everything
Have you pulled a plug and checked for fire? There is a huge difference between crank and no fire or crank and no start. If you have spark, make sure air filter is clean. Next step make sure you have fuel to the carb. After that the carb would be the next step. Have it cleaned and rebuilt.
Jul 18, 2016 | Craftsman Garden
I changed the deck drive belt & the baldes spin but when I lower the cut height from the highest setting(5) down one (4) the blades spin slows down too much & it's not cutting the grass. I need to...
Sounds like you had to change the belt because their is too much resistance in the shafts that the blades are attached to. This may be from grass. Anyway, that is where I would check, to make sure everything turns freely when not connected to the belt .
May 17, 2014 | Yard Machines 13AN772S000 42-Inch 500cc...
Was cutting grass on my troybilt pony got real loud and shut off now wont crank just spins over replaced sparkplug and it keeps foulin out
Sounds like the plug has stripped the threads, any good machine shop will fit a heli coil ( thread insert ) in the head to restore the thread.
May 12, 2012 | Troy Garden
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replaced blades on Craftsman 21.5 HP B+S engine Model 91-7272460
You might want to check this may sound silly but check to see if the blades were put on upside down.
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere 120 will not crank
Make sure your blades are off.
put your hand on the top of the motor and spin it backwards your starter could be stuck up.
Aug 28, 2008 | Garden
Garden Logo
284 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
