Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
What does flashing red light mean on lg 42lg50
I have a LG 42LG50-UG that has lost power (due to power surge)There is no red standby light. I figured it was the power supply board. I bought a new one and installed it. After having it plugged in for 30...
Have you checked the outlet to see if it has power?? If not, check the circuit breaker for the outlet. Otherwise make sure all the connections on the P/S board are correct and that they are all connected.
Dec 15, 2017 | LG Televison & Video
Blinking blue and red lights will not turn on TV is LG
most likely there is a bulged capacitor on the power supply, just have to replace it.
Sep 14, 2016 | LG 42LG50 42 in. LCD HDTV
Lg 47lg70 turns off and on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 24, 2014 | LG 42LG50 42 in. LCD HDTV
My LG lcd won't turn on
Power supply module will be the first thing the Tech will look at first, parts: http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LG50+
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | LG 42LG50 42 in. LCD HDTV
I have an LG 42lg50 TV that was working fine earlier today, While I was out of the house an Thunderstorm came up and power failed at least twice. I come back home to find my TV not working properly. The...
An electrical pulse from the thunderstorm has affected your TV. (Was it on a surge protector?)
There is a small possibility that it will come back.
Unplug the television and let it sit for an hour or more and then re-plug it.
If you need to get a new TV, also get a good surge protector such as Panamax.
Jun 14, 2010 | LG 42LG50 42 in. LCD HDTV
My tv went out and the light in front which is red or when on is blue slowly strobes red and will not come on
I think your mean “your TV can't turn on, and the LED red light off too” If it is true, you shall check the power switch first, because only the LG TV have the power switch (Sony 2010 model’s does). If I guess wrong, please provide more information, I wish I can help you.
May 08, 2010 | LG 42LG50 42 in. LCD HDTV
Pair sky+ remote to tv
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Jan 10, 2009 | LG 42LG50 42 in. LCD HDTV
42lg50
try and unplug it, wait, plug back in and try it.
Aug 16, 2008 | LG 42LG50 42 in. LCD HDTV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
