Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Stanley rider model 425605x692 need drive belt diagram, routing around the tensioner pully old belt broke, and i ain't gotta clue how it was installed thanks
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
  • 376 Answers
SOURCE: belts coming off lawn mower troy built 46" 21hp horse 14at809h766
Go to... http://www.managemyhome.com/mmh/owner_manuals and enter your model # that under the seat.
Posted on May 25, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
mickey813
  • 472 Answers
SOURCE: how to install belt on mower-Model#917.287320
if you will go sears parts and put in the 917287320 in the box and will show you one ok
Posted on Feb 22, 2010
2000 grand Prix how to fix belt when it comes off
If it a serpintine belt (meaning one belt runs everything) and it comes off on its own its time for a new belt to install new or reinstall old one . All cars have abelt routing diagram if not google your car and year asking for belt diagram. Locate tensioner usually turns with wrench ( socket or box end is best) route the belt according to dia. leave tensioner for last rotate pully with wrench to get belt over release tension on wrench thats all there is to it. But if belt keeps coming off usually indicates new belt is needed could also need tensioner pully its a good idea to replace both at the same time
May 19, 2018 | 2000 Pontiac Grand Prix
Install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
Aug 30, 2012 | Garden
My dodge sprinter 213 cdi with AIR CON though
Over to right pulley (bottom the a/c) then over rider pully to top left pully to alternator to fan down to drive to tensioner
Feb 27, 2010 | 2002 Dodge Sprinter
Need a diagram for tumbler belt placement on the motor pulleys
Mot sure which dryer you own, however it typically goes like this. Belt around drum, position in the tracks where the old one was, (usually some visable rubber residue), then around the motor pully, lastly, compress the tensioning device and route belt onto the cradle then release the tension.
Oct 07, 2009 | Dryers
Having trouble replacing a 42 craftsman riding mower belt...help Ithe old one broke off but the new one it on too tight...the replacement one is the right lenght help please
do you remember the routing of the belt? there should be a diagram on the deck somewhere - best thing to do is rout the belt while the deck is lowered, leaving the loop at the front to put around drive pully on bottom of engine. once that is all hooked up, there are deck adjusters on either side of the deck - that you can adjust to relieve some of the tension on the belt - turn the adjusters clockwise to tighten, counterclockwise to loosen - let me know if this helps or if u need more info - i have a 10 year old 42" deck tractor out in my barn and if need be, tomorrow i will walk u through - online how to adjust the deck
Sep 06, 2009 | Craftsman Garden
Serpintine belt routing 95 dodge spirit
moz-screenshot.jpgYou can find one at autozone.com, you may have to sign up for a free account, but you can view the job diagram there. It looks like for a 6 cylinder, there are two belts, one goes from the crank pully around the water pump then the alternator, and the other goes around the crank shaft then the power steering pump and then the air compressor pully. The power steering and air is a "v" belt and the other is a ribbed serpentine belt. they both just wrap around no wierd routing. the only thing I do not see is the idler pully or tensioner pullys.
Jun 24, 2009 | 1995 Dodge Spirit
Belt inst
For the 3.0L Vulcan, you have a tensioner that is located just below the power steering pully. Use a 15mm wrench or the 15mm shallow well socket that comes in a Serpentine Belt tool to push the tensioner toward the rear of the engine compartment. Take the old belt off and route the new belt. The belt begins at the crankshaft pully, goes under and around the a/c compressor, up around the power steering pump, around (with the flat edge) the idler pully, around the alternator, the flat edge then sits against the tensioner and back around to the water pump pully. You should have a belt routing diagram on the underside of the hood just above the serpentine pully assembly.
Jun 23, 2009 | 1999 Ford Taurus
I own a ford focus 2006 the belt fell off I'm not sure which one and a need to be able to put it back on.
well, the belt does not just fall off. If the belt has come off it's because one of the pullys have failed.there is only 1 belt on that car, there should be a diagram under the hood that says "drive belt routing"
You need to release tension on the tensioner pully with a serpentine belt tool or a long 3/8" breaker bar. rout the belt according to the diagram, then re apply the tension
May 17, 2009 | 2006 Ford Focus
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
613 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
