Question about Samsung 710V 17" LCD Monitor
What is the power cord type for samsung syncmaster 710v
    President:
  • 3,085 Answers
2 Suggested Answers
  • 36 Answers
SOURCE: cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
Samsung SyncMaster 710v isnt responding, keeps
Hello , this is very common problem with this model .
The problem is with main board there are two solutions:
1.Replace the main board with proper part
2.The trick you can try is to add resistor 47ohm on main board chip between two pins.
If you are not familiar with electronics do not attempt to repair it by self , go to proper service center. There is always possibility of electrolyte-shock, or high voltage shock . Hope this helps.
Fix Samsung SyncMaster 710v Not Optimum Mode Recommended Mode 1280 1024 60...
Oct 12, 2014 | Computers & Internet
How to connect syncmaster710v to pc
Make sure your monitor and computer have the same type of video output port on it (either VGA/D-sub that is usually blue, or DVI that is usually white). If not, you may need to pick up an adaptor. Next, locate the appropriate cable, which should have come with the monitor, and connect it from your computer's video card to the monitor's video input. Then, connect the power cable from the monitor to the wall. Setup the rest of the computer and turn it on.
Jun 22, 2011 | Samsung SyncMaster 710V/710M,SyncMaster...
ALWAYS SHOW " 1024 X 768" HERZT. CAN'T SHOW
Hi, Same problem as mine! Are u suing the original Samsung CX511n cable? If not, video will not appear! Buy the original cable!
Jun 15, 2011 | Samsung SyncMaster 510N/512N,SyncMaster...
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Where is the source button on the samsung 710v
the 710V samsung monitor has only vga analog input. so there is no source button
Feb 19, 2009 | Samsung 710V 17" LCD Monitor
Samsung 710V - controller box
your monitor's video section is fault change video amp. ic or check cpu cable(vga cable).
Oct 20, 2007 | Samsung 710V 17" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
302 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
