Question about Vizio P50HDTV10A 50 in. Plasma HDTV
55'' vizio screen color is distorted
After about an hour of the tv being on the screen color gets distorted, if I turn the tv off and then back on its fine for a couple of minutes but generally have to let it cool off for a long period of time.
  • 67 Answers
I have been pleased with the help from Vizio. Try techsupp@ vizio.com. Good luck. I believe they respond within 48hrs.
Posted on Jun 27, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
Dec 10, 2015 | Vizio VF550M 55 in. LCD HDTV
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
I have a 55' Vizio Tru LED model VF552XVT. The TV ran fine for a year and a half and just recently the screen started shutting off after a few hours. I am aware that there is an issue where Vizio
It sounds like an overheating issue with the T-con board. You shouldn't have to run a house fan behind the TV to keep the screen on. Make sure you have the TV in a place where there is enough space around it to allow for air flow. Also, check to make sure the ventilation slots on the back of the TV are not blocked with dust.
Aug 30, 2012 | Vizio VF552XVT 55" inch Class XVT Series...
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
The color on my 55
Change the coolant fuild in R/G/B Tubes.
Dec 30, 2009 | Philips 55PW9363 55" Rear Projection...
Vizio 32'' VO320E Image Distortion
I hope not but:
this is probably a failure from the screen or the electronic parts that control the videosignals.
i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
Hope this is helpful, and greetings,
Olivier.
Oct 21, 2009 | Vizio VO320E LCD TV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
485 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
