Question about Honeywell CT3600 7 Day Electronic Programmable Thermostat Heater
Have a Honeywell CT3600 Thermostat. Temp won't go below 85
Won't cool below 85 during the day and 70at night. We live in Houston so this is not good when it is 105 outside
  • 24 Answers
SOURCE: Honeywell Digital Thermostat won't click on if temp is below 59
do you live there? if so here are the rules for setting back temperature: do not lower the temperature more than 8 degrees F from the temperature you want it when your there, setting it back for periods of less than eight hours is also somewhat futile. Due to laws of thermo-dynamics the heat required to recover from more extreme setbacks or shorter periods of time exceeds the savings acquired by taking said action. As to your question directly there are no reasons why your thermostat should not function at any setpoint temperature that it is allowed to set to (45 normally being the lowest) if it does not function below 58 degrees it has a failure and should be replaced before it fails completely. Suggest a Robertshaw or Braeburn brand thermostat, Honeywell quality has slipped over the past decade to unacceptable levels. Unless your considering a Hunter in which case buy another Honeywell.
Posted on Dec 18, 2008
SOURCE: EEE error message
I just talked to Honeywell support - they claim that an eee error means there has been a "unique error" and that the unit will need to be replaced - cannot be fixed. They were pretty good about giving a suggestion for a new thermostat and wiring directions if you want to DIY. Otherwise, call a pro.
Posted on Oct 11, 2008
  • 19 Answers
SOURCE: My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
Posted on May 17, 2009
  • 6 Answers
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Posted on Jun 25, 2009
  • 80 Answers
SOURCE: EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Posted on Oct 07, 2009
Manual honeywell programmable thermostat
Follow the below link, select thermostat on the upper box, then type CT3600 on the lower box.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Oct 09, 2012 | Honeywell CT3600 7 Day Electronic...
Honeywell CT3600 does not turn off heat
Its hard to say where its getting power from. It should be a normally closed two wire valve, so power must be fed from the tstat only? Not real sure how it's wired. You could try a round of MUSICAL THERMOSTATS? That would answer your question as long as its played properly.
Mar 25, 2017 | Honeywell CT3600 7 Day Electronic...
Tempstar 10 not blowing cold air
Hello, sounds like the unit may have a low refrigerant charge due to a leak. It cannot keep up with the heat load during warmest parts of the day is a sign of a low charge.
May 06, 2012 | Heating & Cooling
Lg air condition doesn't work when it is cold outside
Sounds like the crankcase heater. This is likely hooked to a temp sensor that is activated when it gets below a certain temp. There is likely a short in the heater and it trips the breaker. The heater keeps the refrigerant warm inside the compressor when compressor not running. Find a different technician.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 19, 2017 | LG Heating & Cooling
After being on for a whilemy plasma tv picture scrambles. After it cools down the picture is restoredwhat could be the cause
Your plasma is over heating! This is not a good situation for the tv as the components are only rated to their highest temp of 105 degrees C. (IF there are quaility parts inside). Some plasmas are only rated to 85 degrees C. I would recommend installing an internal fan or keep a fan behind the plasma to help cool it during its' working hours!
Please rate if this helps :)
Mar 09, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
Heating & Cooling Logo
176 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
