Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
I am getting error code C7 76 on model RTGG 53DVN
The unit will run for about 15 seconds and then shutdown with htis error code.
  • 4 Answers
I had the same problem. I ordered a replacement remote unit 117 but it malfuctioned also. When orginally installing the unit I had used 16 gauge stranded wire. It was heavier and I thought there would not be a problem well when I decided to try 18/2 solid thermstat wire everything cleared up. Apparently, after two years of use the electrical characteristic of the stranded wire had gone out of the limits for the two units to communicate.
Check to be sure that the wire is 18 gauge solid copper that connect the units.
Posted on Aug 18, 2009
  • 117 Answers
Is a connection between your controller and the unit disconnect the controller and see if it runs if not then it could be the PCB board. check your wires for bad connections on the remote as well
Posted on Aug 02, 2009
  • jwilkie59 Dec 18, 2010
    I tightened the connection to the thermostat, both in the unit and at the thermostat and the C7 76 error code no longer comes up. Thanks!
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
991 error code on a Takagi T-K3 Flash gas tankless water heater
Re- set code!!!!
We have a Takagi TH3 DV 540 model.Air intake got blocked with snow, condensation etc.Once we cleared that then you just have to re-set it to clear the 991. On our model there are 4 tiny buttons across the bottom (Take off front cover) to find them. of the computer board assembly bottom left corner. Push the two buttons on the right simultaneously hold for 15-20 seconds or so, then turn the Takagi off then on again- should work now!
If you have a different model then those buttons will be in the bottom left corner still but running vertically- try doing as above with the bottom two buttons. We had to go without heat and hot water for 2 days until we could get hold of someone to tell us this. We called Seneca Supply 716-852-4744. Good luck
Apr 22, 2012 | RTO Takagi T-K3 Flash Gas Tankless Water...
My unit is a paloma tankless model # PTG-74PVP its throwing error code C4 15 what does this mean? We believe its a flow problem because we hooked up an external pump, it starts out with full flow then...
Could be a restricted inlet pipe just as you suspected.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
error 15 is 'Boiling safety device'
"Check for closed water heater inlet valve or restrictions in cold water inlet pipe (must be fully open).
Check for clogged heat exchanger (scale buildup).
On commercial water heater, lower setpoint temperature below 180F at high altitude."
Open following links for Rheem tankless resources including Rheem chat and phone support:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Jun 14, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
My Rheem RTG-53DVN Direct Vent Natural Gas Tankless Water Heater gets an 11 error code when it sees demand. The manual suggests turning on the gas valve all the way. There is a 3/4" dedicated gas...
Natural gas has a lower pressure/flow rate than propane so through a 3/4" pipe you may not be getting enough at the unit to fire it correctly.
Check that the pipe sizing is correct for the hourly gas consumption of that unit
Mar 06, 2011 | Rheem RTG-53DVN Direct Vent Natural Gas...
I have a RMTG-53dvn piped in parrallel with a traditional water heater because I used to have two traditional in parallel. The unit never kicked on with no trouble code, so I piped in series with a...
I could see how it might not work in parallel. Much water would go thru the conventional heater, so there would be low flow thru the tankless.
Now, the tankless is getting hot water from the conventional. Try shutting the conventional heater's power source off so the water gets cold, then see what happens with the tankless.
Gary
Mar 05, 2011 | Rheem RTG-53DVN Direct Vent Natural Gas...
Paloma (Rheem) tankless water heater 7.4 gpm 199,000 btu outdoor unit. Red light is blinking on pc board. unit fires up for approx 2 seconds then shuts off, then cycles once more for 2 seconds and shuts...
i think your flame sensor is bad but you will need to confirm that with rheem i am unsure what the c7 is for but code 12 is flame failure and there could be carbon build up on the flame rod...
Aug 06, 2010 | Rheem Tankless Hot Water Heater...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
1,466 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
