Question about Royal Sovereign Heating & Cooling
I moved my 3000 to another room. Previously, I could set the temp. Now I can only set a time and I get no cooling. I don't have a manual as this was an "open box" sale. I've tried changing the time to temp but to no avail. Any advice?
    Genius:
  • 1,341 Answers
Can you please provide the made and model number and then I may help you further.
Posted on Jun 27, 2009
Tip
Too cool or over cool in room
Indoor sensor to sense the room temp and must cut off the compressor by working. If sensor defective, compressor will continuously running resulting to over cool in room. And also 23 C degree setting temp is best cooling for office and bed rooms. If for peculiar instrument which should be kept under low temp, can be set as mentioned temp (say 18 C or 16 C )<br />
on Jan 10, 2011 | Heating & Cooling
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
Haier a/c model esa408k-l mode is set on cool, speed set on high temp is 81 held temp button down, goes to 61 with in seconds goes back to 81.
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
Aug 26, 2015 | Haier Heating & Cooling
Just moved and installed my LG airconditioner. it does not cool, but warms.
Check it's in cool mode and temp setting is 3 degree less than room temp Check compressor is working with required pressure.60 PSI@ 98 degree Fahrenheit of ambient temp.If less pressure or no pressure, gas leak. Arrest leak and recharge gas.
Jan 28, 2011 | LG Heating & Cooling
I recently moved to 8yrs old house. Since I moved in Wintor, AC was turned off. Now I need to turn on...where do I find details for that? I don't have manuals? Model: RUDD - UAMB-030JAZ Thx, Satya
Turning on the cooling starts with the thermostat, turn the thermostat to the cooling setting, and then set the temp. setting down below the room temp.
That is the basics,,
If you have more advanced problems, please just get back to me and I can help you work thru some more advanced solutions.
Have a Great Day!
Sincerely,
Paul Gibson
Apr 08, 2010 | Ruud UAMB Air Conditioner
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Samsung window unit air conditioner model # AW2402M freezes up one time, and the next time freezes you out of the room. What is wrong with it, Termistat or compressor?
Try to set the thermostat to higher temperature and monitor if the compressor will turn " off " when the room temp. is cool, and turn " on " when the room temp. is high. If does not work then your thermostat is defective. Continue running of compressor with very cold room temp. can build up ice in the unit. The compressora73b784.jpg should shutdown when setting temp. will attain.
Apr 08, 2008 | Heating & Cooling
Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Dec 13, 2007 | Fahrenheat FFH1615 Heater
Heating & Cooling Logo
Top Royal Sovereign Heating & Cooling Experts
Bill Long
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
